Problem: UCS 5.2 - univention-export-anonymized-ldap fails with KeyError
The tool univention-export-anonymized-ldap fails with a KeyError when exporting an LDAP database containing entries missing the optional attribute krb5PrincipalName. This causes the script to terminate prematurely, resulting in an incomplete export and leftover temporary files. This occurs because the script does not check whether the krb5PrincipalName attribute is present in each LDAP entry before trying to process it.
Temporary files such as /tmp/tmpxxxx.ldif are also not deleted in the event of a crash, which may leave sensitive data on disk.
Product Version:
  • UCS 5.2-x
Description:
When executing the anonymization script on a UCS 5.2-x system, the following error occurs:
Run the following command on a UCS 5.2-x system:
/usr/bin/univention-export-anonymized-ldap --i-understand -o /root/univention-support/LDAP_copy_anonymized
Tracebacks:
Exporting LDAP database...
... saved online data at /tmp/tmpnlux1_01.ldif
... writing anonymized data to /root/univention-support/LDAP_copy_anonymized.ldif
  File "/usr/bin/univention-export-anonymized-ldap", line 185, in <module>
    main()
  File "/usr/bin/univention-export-anonymized-ldap", line 180, in main
    anonymize(ldap_database, output_file=_args.output)
  File "/usr/bin/univention-export-anonymized-ldap", line 83, in anonymize
    entry["krb5PrincipalName"] = [new_cn + b"@" + old.split(b"@")[1] for old in entry["krb5PrincipalName"]]
KeyError: 'krb5PrincipalName'
or
The first database does not allow slapcat; using the first available one (2)
... saved online data at /tmp/tmpvo7r1_77.ldif
... writing anonymized data to /root/univention-support/LDAP_copy_anonymized_66659.ldif
    main()
  File "/usr/bin/univention-export-anonymized-ldap", line 126, in anonymize
    entry["krb5PrincipalName"] = [b"host/" + new_cn + b"." + entry.get("associatedDomain", [b"ucs.test"])[0] + b"@" + old.split(b"@")[1] for old in entry["krb5PrincipalName"]]
If any LDAP entry lacks the krb5PrincipalName attribute, the script crashes with a traceback and does not finish processing.
Root Cause:
The script incorrectly assumes the presence of the krb5PrincipalName attribute without verifying it exists in the LDAP entries.
A patch has been provided that checks for the presence of the krb5PrincipalName attribute before attempting to modify it.
How to Apply the Patch
Follow these steps to apply the patch:
  1. Download the patch:
    wget https://forge.univention.org/bugzilla/attachment.cgi?id=11330 -O NEW-univention-export-anonymized-ldap_patch.diff
  2. Backup the original script:
    cp /usr/bin/univention-export-anonymized-ldap /usr/bin/univention-export-anonymized-ldap.bak
  3. Make the patch file executable:
    chmod +x NEW-univention-export-anonymized-ldap_patch.diff
  4. Install the patch utility if it’s not already available:
    apt install patch
  5. Apply the patch:
    patch /usr/bin/univention-export-anonymized-ldap NEW-univention-export-anonymized-ldap_patch.diff
Output:
patching file /usr/bin/univention-export-anonymized-ldap
Final Result
After applying the patch, the tool should work as expected:
/usr/bin/univention-export-anonymized-ldap --i-understand -o /root/univention-support/univention-export-anon/LDAP_copy_anonymized
... saved online data at /tmp/tmprpoy8yg3.ldif
... writing anonymized data to /root/univention-support/univention-export-anon/LDAP_copy_anonymized.ldif
We anonymized or removed what we considered worthy. Usernames, birthdays, mail addresses, etc. Please note that there may be remnants of technical data, e.g., server names, DNS data, etc. Also, maybe some user data that needed protection was saved in attributes we did not consider or we did not know of (objects can be extended by Apps, ...). Please check the file before sending somewhere: /root/univention-support/univention-export-anon/LDAP_copy_anonymized.ldif
... and removed online data again /tmp/tmprpoy8yg3.ldif
