Problem: Traceback when creating simple auth user
I receive a traceback when I create a simple auth user
root@dc0:~ # udm users/ldap create --position cn=users,$(ucr get ldap/base) --set username="authacc" --set password="abcdefg12345"
  File "/usr/share/univention-directory-manager-tools/univention-cli-server", line 219, in doit
    output = univention.admincli.admin.doit(arglist)
  File "/usr/lib/python2.7/dist-packages/univention/admincli/admin.py", line 409, in doit
    out = _doit(arglist)
  File "/usr/lib/python2.7/dist-packages/univention/admincli/admin.py", line 755, in _doit
    dn = object.create()
  File "/usr/lib/python2.7/dist-packages/univention/admin/handlers/__init__.py", line 557, in create
    dn = self._create(response=response, serverctrls=serverctrls)
  File "/usr/lib/python2.7/dist-packages/univention/admin/handlers/__init__.py", line 1241, in _create
    al.extend(self._ldap_modlist())
  File "/usr/lib/python2.7/dist-packages/univention/admin/handlers/users/ldap.py", line 223, in _ldap_modlist
    self._check_password_complexity(pwhistoryPolicy)
  File "/usr/lib/python2.7/dist-packages/univention/admin/handlers/users/ldap.py", line 302, in _check_password_complexity
    pwdCheck.check(self['password'], username=self['username'], displayname=self['displayName'])
  File "/usr/lib/python2.7/dist-packages/univention/admin/handlers/__init__.py", line 478, in __getitem__
    elif key not in self.__no_default and self.descriptions[key].editable:
KeyError: 'displayName'
Environment
Password-Policy and Password quality check is enabled
Bug 52446 not fixed
Solution (is probably more of a workaround)
As a workaround disable the complexity check in LDAP.
UMC -> domain -> LDAP directory -> policies -> users -> pwhistory -> uncheck the box at the bottom.
Wait a short time and then try to create the user again. After successful creation of the simple auth user you can enable the complexity again.
Root Cause
If the Password quality check is enabled, it will be checked if the display name is included in the password. A Simple Auth user has no display name, which leads to this traceback.
We need to adjust the check accordingly. This is traced in the above bug.
