Teacher’s computer is locked out of internet access due to exam mode/computer room settings
Explanation:
Teacher computers are currently subject to the same restrictions as the student computers in exam mode. This means that access to shares will be restricted and, even worse, Internet access will also be restricted/prevented.
This can lead to the teacher locking himself out because, for example, the client systems are configured via a firewall so that HTTP/HTTPS access can only take place via the proxy. If the proxy prohibits any access by the rule “No Internet”, the teacher is locked out.
Workaround:
- You can add the portal to the “no internet” rule
- You can create an exception for the portal directly in the firewall for the teacher machines.
In the meantime you can select a PC as a teachers PC in the room management
