Sysvol-sync - placing triggerfile with ssh failed
You find error messages like this in the /var/log/univention/sysvol-sync.log file:
2020-11-22 08:15:40 ERROR [master] placing triggerfile with ssh failed with 1. (Could not chdir to home directory /dev/null: Not a directorybash: /dev/null/.bashrc: Not a directorytouch: cannot touch '/var/cache/univention-samba4/sysvol-sync/.trigger/schule1': Permission denied)
Please check the permissions of the directories in /var/cache/univention-samba4/sysvol-sync/.trigger of the machine, which is specified between the square brackets at the beginning of the error messages
root@master:~# ls -lst /var/cache/univention-samba4/sysvol-sync/.trigger
insgesamt 0
0 -rw-r--r-- 1 Schule2$ DC Slave Hosts 0 Dez 11 12:26 Schule2
0 -rw-r--r-- 1 Schule3$ DC Slave Hosts 0 Dez 11 12:25 Schule3
0 -rw-r--r-- 1 Schule4$ DC Slave Hosts 0 Dez 11 12:25 Schule4
0 -rw-r--r-- 1 opsi$ DC Backup Hosts 0 Dez 11 12:25 opsi
0 -rw-r--r-- 1 Schule5$ DC Slave Hosts 0 Dez 11 12:25 Schule5
0 -rw-r--r-- 1 Schule6$ DC Slave Hosts 0 Dez 11 12:25 Schule6
0 -rw-r--r-- 1 8780 DC Slave Hosts 0 Nov 11 12:10 Schule1
0 -rw-r--r-- 1 6152 DC Slave Hosts 0 Aug 29 2019 Schule7
As you can see the owner of the directory should be the Host. The group membership should correspond to the server role. If it is not, the server machine account is not allowed to place the trigger file. Simply chown the directory to the host machine account:
root@master:~# chown Schule1$ /var/cache/univention-samba4/sysvol-sync/.trigger/Schule1
root@master:~# chown Schule7$ /var/cache/univention-samba4/sysvol-sync/.trigger/Schule7
Root Cause
This problem arises from reinstallations of domain members.
When reinstalling a server, simply shut down the original server and install the new one with the same hostname. If the join is not executed directly during the installation please do a complete:
univention-join
and not only …run-join-scripts
see also:
Optional:
You will find the following information in /var/log/univention/sysvol-sync.log
2025-08-27 06:47:59 ERROR [ucs-pri01] placing triggerfile with ssh failed with 255. (ssh: connect to host ucs-primary port 22: Connection timed out)
2025-08-27 06:47:59 ERROR [ucs-pri01] Placing a trigger file failed.
Check the network settings in your environment so port 22 is open and available.
If the port 22 is blocked, also sysvol-sync scripts could not be execute successfully.
