After rebooting the fileserver, not all NFS mounts were successfully mounted.
In particular, the mount point:
/mnt/server/share
was missing, causing some shares to be unavailable.
The following messages appeared in the system logs:
root@fs:~# dmesg | grep share
[ 8.622998] systemd[1]: nfs-server.service: Found ordering cycle on mnt-server-share.mount/start
[ 8.623007] systemd[1]: nfs-server.service: Job mnt-server-share.mount/start deleted to break ordering cycle starting with nfs-server.service/start
The relevant fstab entry was:
... /mnt/server/share nfs tcp,vers=3,async,rdirplus,rsize=32768,wsize=32768 0 0
Cause
The NFS mount /mnt/server/share points to a remote server. By default, systemd automatically adds a dependency between NFS mounts and the local nfs-server.service.
This creates a circular dependency during boot:
nfs-server.service → mnt-server-share.mount → nfs-server.service
Since systemd cannot resolve this dependency cycle, it cancels the mount operation. This explains the error message seen in the logs and why the share was not mounted automatically.
There are two recommended approaches to fix this issue:
1. Automatic Mount on Demand
Update the fstab entry as follows:
... /mnt/server/share /mnt/server/share nfs tcp,vers=3,async,rdirplus,rsize=32768,wsize=32768,noauto,x-systemd.automount 0 0
noautoprevents systemd from mounting the share immediately at boot.x-systemd.automountensures that the share is mounted automatically the first time it is accessed.
This avoids dependency issues while still making the share available when needed.
2. Mount After Network Availability
Alternatively, you can mark the mount as network-dependent by using _netdev:
... /mnt/server/share /mnt/server/share nfs tcp,vers=3,async,rdirplus,rsize=32768,wsize=32768,_netdev 0 0
_netdevtells systemd to delay mounting until the network stack is fully up and running.
