You created an extended attribute, with syntax UserDN like this:
base="cn=univention,$(ucr get ldap/base)"
udm settings/extended_attribute create --position "cn=custom attributes,$base" \
--set name="DelegateUser" \
--set module='users/user' \
--set tabName='Microsoft 365' \
--set groupName='DEU' \
--set shortDescription='Delegated User' \
--set translationShortDescription='"de_DE" "Postfachstellvertretung"' \
--set longDescription='users who are allowed to access the mailbox of the current user' \
--set translationLongDescription='"de_DE" "Personen, welche auf das Postfach der derzeitigen Person zugreifen dürfen"' \
--set objectClass='univentionFreeAttributes' \
--set ldapMapping='univentionFreeAttribute7' \
--set syntax="UserDN" \
--set mayChange=1 \
--set valueRequired=0 \
--set doNotSearch=1 \
--set multivalue=1 \
--set default="" \
--set copyable=1
If you rename a user (wedding) this UserDN is not updated in this attribute field. This is because there is no mechanism behind that. So you have to create a hook, watching the changes or more simple and easier you use the refint overlay.
root@ucs:~# ucr info ldap/refint
ldap/refint: false
Whether or not the refint overlay should be enabled. It enforces referential integrity for the attribute uniqueMember. Only applies to the DC Master.
Categories: service-ldap
Default: true
Type: bool
You set the ldap/refint
root@ucs:~# ucr set ldap/refint='true'
Setting ldap/refint
Multifile: /etc/ldap/slapd.conf
Per default only uniqueMember is watched, so you have to adjust (unfortunately directly in the template)
vim /etc/univention/templates/files/etc/ldap/slapd.conf.d/40univention-ldap-server_database
if configRegistry.is_true('ldap/refint', True) and configRegistry.get('server/role') == 'domaincontroller_master':
print('overlay\t\trefint')
# print('refint_attributes\t\tuniqueMember')
print('refint_attributes\t\tuniqueMember\tuniventionFreeAttribute7\tuniventionFreeAttribute8 ')
Commit the /etc/ldap/slapd.conf
ucr commit /etc/ldap/slapd.conf
systemctl restart slapd
But you have to be aware, that future changes at the modified template by an update may not happen due to these changes!
root@ucs:~# univention-check-templates
WARNING: The following UCR files are modified locally.
Updated versions will be named FILENAME.dpkg-*.
The files should be checked for differences.
FR is 56721
