Problem: Start of OpenLDAP Fails with "undefined slapschema"
Start of OpenLDAP fails with "undefined slapschema"
Following this error the notifier and listener services are not in sync.
Environment
An attempt to start the OpenLDAP server fails and journalctl -xe shows:
root@ucs:/var/log/univention# service slapd status
● slapd.service - LSB: OpenLDAP standalone server (Lightweight Directory Access Protocol)
   Loaded: loaded (/etc/init.d/slapd; generated; vendor preset: enabled)
   Active: failed (Result: exit-code) since Thu 2019-03-21 10:34:53 CET; 6min ago
  Process: 791 ExecStart=/etc/init.d/slapd start (code=exited, status=1/FAILURE)
      CPU: 156ms
Mär 21 10:34:48 ucs systemd[1]: Starting LSB: OpenLDAP standalone server (Lightweight Directory Access Protocol)...
Mär 21 10:34:51 ucs slapd[1090]: @(#) $OpenLDAP: slapd  (Aug  6 2018 15:28:57) $
                                            Debian OpenLDAP Maintainers <pkg-openldap-devel@lists.alioth.debian.org>
Mär 21 10:34:53 ucs slapd[791]: Starting ldap server(s): slapd...
/etc/ldap/slapd.conf: line 77: index attribute "memberOf" undefined
Mär 21 10:34:53 ucs systemd[1]: slapd.service: Control process exited, code=exited status=1
Mär 21 10:34:53 ucs systemd[1]: Failed to start LSB: OpenLDAP standalone server (Lightweight Directory Access Protocol).
Mär 21 10:34:53 ucs systemd[1]: slapd.service: Unit entered failed state.
Mär 21 10:34:53 ucs systemd[1]: slapd.service: Failed with result 'exit-code'.
The main error message from above log snipplet is “Index attribute "memberOf" undefined”. The to-be-indexed attributes are defined through ucr variables.
Step 1
First check if the “memberOf” is properly installed. Output should look like this:
root@ucs:~# dpkg -l | grep member
ii  univention-ldap-overlay-memberof                    10.0.0-4A~4.3.0.201802051318                     all          configuration for OpenLDAP memberOf overlay module
Step 2
Verify the memberOf is activated and shows the following ucr-variables:
root@ucs:~# ucr dump | grep memberof
ldap/overlay/memberof/dangling: ignore
ldap/overlay/memberof/member: uniqueMember
ldap/overlay/memberof/memberof: memberOf
ldap/overlay/memberof/modifiersname: cn=admin,dc=univention,dc=unconfigured
ldap/overlay/memberof/refint: false
ldap/overlay/memberof: true
Step 3
Re-write the OpenLDAP configuration file in order to match the UCS settings:
root@ucs:~# ucr commit /etc/ldap/slapd.conf
root@ucs:~# systemctl start slapd
If it still fails with the same error, go ahead with the following troubleshooting steps.
Step 4
Check for manual changes on the Univention templates. It should show no edits:
root@ucs:~# univention-check-template
Step 5
As slapd complains about some index issues with member of, figure out the current ucr-variables regarding these values.
root@ucs:~# ucr dump | grep index
ldap/index/eq: aRecord,automountInformation,cNAMERecord,cn,memberof,description,dhcpHWAddress,displayName,entryUUID,gidNumber,givenName,homeDirectory,krb5PrincipalName,macAddress,mail,mailAlternativeAddress,mailPrimaryAddress,memberUid,objectClass,ou,pTRRecord,relativeDomainName,sambaAcctFlags,sambaDomainName [...]
The above output shows the “memberof” in the “eq index”. This is uncommon and causes the issue.
Step 6
Set the ucr-variable to a value without the “memberof” attribute by using cut&paste for the remaining values:
root@ucs:~# ucr set ldap/index/eq=\ aRecord,automountInformation,cNAMERecord,cn,description,dhcpHWAddress,displayName,entryUUID,gidNumber,givenName,homeDirectory,krb5PrincipalName,macAddress,mail,mailAlternativeAddress,mailPrimaryAddress,memberUid,objectClass,ou,pTRRecord,relativeDomainName,sambaAcctFlags,sambaDomainName [...]
Step 7
Commit changes and restart slapd:
