Squid crashes on UCS 5 System with the following error in cache.log:
BrokenPipeError: [Errno 32] Broken pipe
File "/usr/lib/squid/squid_ldap_ntlm_auth", line 649, in <module>
sys.stdout.write(answer + "\n")
File "/usr/lib/squid/squid_ldap_ntlm_auth", line 596, in <module>
data = sys.stdin.buffer.readline()
ConnectionResetError: [Errno 104] Connection reset by peer
Reason
Hint
Fixed in Debian with squid Source-Version: 4.9-1
UCS squid version is
Inst squid (4.6-1+deb10u9A~5.0.6.202401091025 Univention Corporate Server:5.0.6-errata/errata506 [amd64])Package: univention-squid
Version: 13.0.7-3
Workaround
You can try to set the restart policy for squid to always, than squid will be restarted even if it exited with exit code 0:
Create /etc/systemd/system/squid.service.d/override.conf and add the following lines:
[Service]
Restart=always
