TLDR
- Problem: SMB shares failed after renaming network adapters.
- Cause: Network adapter changes were manually written to
/etc/univention/base.confbut aucr commitwas not run.- Effect: The missing
ucr commitmeant the change wasn’t applied tosmb.conf, so Samba still pointed to the old, non-existent interface.- Solution: Run
ucr commiton the affected server, then reboot.
After a domain-wide update to Univention Corporate Server (UCS) 5.2 and a migration of all virtual machines, many Samba (SMB) shares became inaccessible. The network adapters’ names were changed during the migration. The UCS domain consists of a Primary Directory Node, two Backup Directory Nodes, and several Replica Directory Nodes. Each Replica Directory Node hosts different SMB shares that school computers and other clients need to access. However, access is only possible on two of these servers, with the rest denying all connections.
Root Cause
The issue stemmed from an incomplete configuration update. After the migration and network adapter renaming (done manually in /etc/univention/base.conf), the ucr commit command was only applied to the interfaces/* Unified Configuration Registry (UCR) scope. This meant that while the samba/interface UCR variable still correctly referenced the interfaces/primary value, this change was not written to the smb.conf file. As a result, the Samba configuration continued to use the old, now non-existent, network interface name, preventing it from binding to the correct network adapter and serving the shares.
To resolve this problem, you need to re-commit the entire UCR and then restart the relevant services. This forces the system to write all new configuration settings, including the correct network interface name for Samba, to their respective configuration files.
Commit the full UCR: Open a terminal on the affected Replica Directory Node and run the following command to commit all UCR changes.
ucr commitThis command ensures that all UCR variables are properly written to their respective configuration files.
Restart the system: After committing the changes, a full system reboot is necessary to apply the new network and Samba configurations.
rebootAlternatively, if a full reboot isn’t feasible, you can try restarting the Samba service specifically, but a reboot is the most reliable way to ensure all dependencies are correctly initialized.
