slapd service is not starting
A root cause could be a full hard disk.
Investigation:
Try to start the service with
/usr/sbin/slapd -h 'ldapi:/// ldap://:7389/ ldaps://:7636/' -d5
If you find this kind of message at the end:
$ ipsecNFAReference $ ipsecISAKMPReference $ ipsecNegotiationPolicyReference $ ipsecFilterReference $ nextLevelStore $ managedBy $ ucsschoolClassShareFileServer $ univent
ionAbordnungMasterDn ) )
61825bd1 2.5.13.0 (objectIdentifierMatch): matchingRuleUse: ( 2.5.13.0 NAME ‘objectIdentifierMatch’ APPLIES ( supportedControl $ supportedExtension $ supportedFeature
s $ supportedApplicationContext $ pwdAttribute ) )
TLS: could not read DH parameters file `/etc/ldap/dh_2048.pem’.
TLS: error:0906D06C:PEM routines:PEM_read_bio:no start line …/crypto/pem/pem_lib.c:686
61825bd1 main: TLS init def ctx failed: -1
61825bd1 slapd destroy: freeing system resources.
61825bd1 OVER: Dellog db_destroy
61825bd1 OVER: db_destroy
61825bd1 slapd stopped.
61825bd1 connections_destroy: nothing to destroy.
the indication is:
Check the file in
ls -lah /etc/ldap/
insgesamt 100K
drwxr-xr-x 5 root root 4,0K Nov 3 10:49 .
drwxr-xr-x 141 root root 12K Nov 3 10:46 ..
-rw-r--r-- 1 root root 0 Nov 3 04:31 dh_2048.pem
If it is 0 byte we need the default one.
The slapd dh_2048.pem can be copied from /usr/share/univention-ldap/
ls -lah /usr/share/univention-ldap/
-rw-r--r-- 1 root root 424 Jun 29 13:22 dh_2048.pem
So copy and start slapd again
root@ucs: cp /usr/share/univention-ldap/dh_2048.pem /etc/ldap/
root@ucs: systemctl start slapd
root@ucs: /usr/share/univention-ldap# ps aufx |grep slap
root 16483 0.0 0.0 14316 944 pts/2 S+ 10:57 0:00 | \_ grep slap
root 16450 21.2 2.3 14408892 380008 ? Ssl 10:57 0:01 /usr/sbin/slapd -h ldapi:/// ldap://:7389/ ldaps://:7636/
