Shares access and AD-Connector are not working anymore.
AD-Membermode. ( Member in Microsoft AD)
Investigation:
After more than one failed server-password-changes, the machine.secret could not be rotated in AD.
root@ucs:~# wbinfo -t
checking the trust secret for domain SCHEIN via RPC calls failed
wbcCheckTrustCredentials(SCHEIN): error code was NT_STATUS_DOMAIN_CONTROLLER_NOT_FOUND (0xc0000233)
failed to call wbcCheckTrustCredentials: WBC_ERR_AUTH_ERROR
Could not check secret
Try to find the still working password in
/etc/machine.secret.old
and test it with
kinit <hostname>$ (please replace <hostname> with the hostname of the system)
If you find the working password, then you can reset the password with the actual machine.secret.
kpasswd <hostname>$ (please replace <hostname> with the hostname of the system)
type the olf working machine.secret and than set the new machine.secret (cat /etc/machine.secret;echo)
Maybe this is not enough, so it is also possible to set the machine.secret in AD with a powershell command like this:
Make sure to use the right dn of the ucs-primary-dc located in AD and the new machine.secret
Set-ADAccountPassword 'CN=ucs-primary,OU=Computers,OU=MyBusiness,DC=schein,DC=ig' -Reset -NewPassword (ConvertTo-SecureString -AsPlainText “gRF66Qrp52ZevRVdUz92” -Force)
There is a Patch available: You can after applying the patch simply redo a manually server password change (Manually trigger server password change)
--- /usr/lib/univention-server/server_password_change.d//univention-samba.orig 2022-10-12 16:38:08.204940850 +0200
+++ /usr/lib/univention-server/server_password_change.d/univention-samba 2022-10-12 16:41:07.767023180 +0200
@@ -95,9 +95,13 @@
# change password on ad in member mode
if samba_role == 'memberserver' and univention.lib.admember.is_localhost_in_admember_mode(ucr=ucr):
- cmd = ['/usr/bin/net', 'ads', 'password', '-P']
- cmd.append('%s$' % ucr.get('hostname', '').upper())
- cmd.append(machine_password)
+ #cmd = ['/usr/bin/net', 'ads', 'password', '-P']
+ #cmd.append('%s$' % ucr.get('hostname', '').upper())
+ #cmd.append(machine_password)
+ cmd = ['/usr/bin/samba-tool', 'user', 'password']
+ cmd.append('--newpassword=%s' % (machine_password))
+ cmd.append('-U=%s$' % ucr.get('hostname', '').upper())
+ cmd.append('-P')
process = subprocess.Popen(cmd)
process.wait()
You may want to deactivate the server-password-change til Bug 54390 is fixed:
