Problem:Schoolreplica can´t join - python3-ucsschool-lib but should not be installed
It is not possible to join a UCS replica to the domain because dependent packages cannot be installed for the join.
You will find the error in the /var/log/univention/join.log
The following packages have unfulfilled dependencies:
ucs-school-umc-installer : Depends on: python-ucs-school but should not be installed
Depends on: python3-ucsschool-lib but should not be installed
Depends on: univention-management-console-server (>= 12.0.31-10) but 12.0.17-3A~5.0.0.202302071823 should be installed
File: /usr/share/univention-management-console/modules/apps.xml
File: /etc/apt/apt.conf.d/55user_agent
File: /usr/share/univention-management-console/i18n/en/apps.mo
Create repository/online
File: /etc/apt/mirror.list
File: /etc/apt/sources.list.d/15_ucs-online-version.list
File: /etc/apt/sources.list.d/20_ucs-online-component.list
ERROR: join/pre-joinscripts hook /tmp/tmpnh0xi_zo/tmposdjsx5l failed.
Bug 56925
Hint:
The dependency change of ucs-school-umc-installer requires univention-management-console-server >= 12.0.31-10 but this is fulfilled beginning with UCS 5.0-4errata765
Make sure that there is no version conflict between the Primary Node and the Replica Node.
  1. Update the Replica Node to latest patch level version to receive and install the errata updates.
For UCS 5.0-6
univention-upgrade --ignoressh --ignoreterm --updateto=5.0-6 --noninteractive
For UCS 5.0-5
univention-upgrade --ignoressh --ignoreterm --updateto=5.0-5 --noninteractive
For UCS 5.0-4
univention-upgrade --ignoressh --ignoreterm --updateto=5.0-4 --noninteractive
  1. Join the system in the domain via shell as root.
univention-join
For more information about the domain join or the installation for a Schoolreplica, check the manual please:
https://docs.software-univention.de/ucsschool-manual/latest/de/installation/multi.html#installation-eines-schulservers
