SASL authentication failure - SMTPS endpoint not reachable
Mail clients cannot be configured because the secure SMTP (SMTPS) endpoint cannot be reached. As a result, authentication via SASL fails and mail clients are unable to establish a secure connection.
In /var/log/mail.log or journalctl, the following errors appear:
postfix/smtps/smtpd[550828]: oauthbearer_client_plug_init() failed in sasl_server_add_plugin(): error when parsing configuration file
postfix/smtps/smtpd[553318]: warning: SASL authentication failure: cannot connect to saslauthd server: No such file or directory
postfix/smtps/smtpd[553318]: warning: SASL authentication failure: Password verification failed
postfix/smtps/smtpd[553318]: warning: unknown[10.159.92.27]: SASL PLAIN authentication failed: generic failure, sasl_username=user@example.com
Environment:
UCS version: 5.2-3 errata248
Installed components:
fetchmail=6.4.37mailserver=16.0ox-connector=3.0.0oxseforucs=7.10.6-ucs11
Relevant packages:
libsasl2-2:amd64 2.1.28+dfsg-10 libsasl2-modules:amd64 2.1.28+dfsg-10 libsasl2-modules-oauthbearer 1.0.0-5 sasl2-bin 2.1.28+dfsg-10 univention-sasl 10.0.2
Investigation:
By default, on UCS 5.2 systems, the saslauthd service is installed but not enabled automatically.
When checking the service status, the output may show the service as active (exited):
systemctl status saslauthd
● saslauthd.service - LSB: saslauthd startup script
Loaded: loaded (/etc/init.d/saslauthd; generated)
Active: active (exited) since Mon 2025-11-03 22:02:04 CET; 1s ago
Process: 484615 ExecStart=/etc/init.d/saslauthd start (code=exited, status=0/SUCCESS)
CPU: 32ms
Nov 03 22:02:04 ucs5primary systemd[1]: Starting saslauthd.service - LSB: saslauthd startup script...
Nov 03 22:02:04 ucs5primary saslauthd[484615]: To enable saslauthd, edit /etc/default/saslauthd and set START=yes ... (warning).
Nov 03 22:02:04 ucs5primary systemd[1]: Started saslauthd.service - LSB: saslauthd startup script.
The system logs indicate:
In /etc/default/saslauthd, the following line is missing:
# Should saslauthd run automatically on startup? (default: no)
START=yes
Without this configuration, the /var/run/saslauthd/ directory and corresponding socket files are created incorrectly or not initialized, preventing Postfix from connecting to the SASL authentication daemon.
Example output:
total 968K
drwx--x--- 2 root sasl 140 3. Nov 23:43 .
drwxr-xr-x 39 root root 1,4K 5. Nov 04:19 ..
-rw------- 1 root root 0 3. Nov 23:43 cache.flock
-rw------- 1 root root 963K 3. Nov 23:43 cache.mmap
srwxrwxrwx 1 root root 0 3. Nov 23:43 mux
-rw------- 1 root root 0 3. Nov 23:43 mux.accept
-rw------- 1 root root 7 3. Nov 23:43 saslauthd.pid
Root Cause
The template file /etc/univention/templates/files/etc/default/saslauthd does not enable automatic startup of the saslauthd service.
This issue is tracked under Bug #58791.
Workaround
Edit the UCS template:
/etc/univention/templates/files/etc/default/saslauthd -
Add or ensure the following line is present at the beginning:
# Should saslauthd run automatically on startup? (default: no) START=yes -
Apply the change:
ucr commit /etc/default/saslauthd -
Restart the
saslauthdservice:systemctl restart saslauthd.service
Verification
After applying the workaround, verify that the service is running properly:
systemctl status saslauthd.service
Expected output:
Active: active (running)
CGroup: /system.slice/saslauthd.service
├─491931 /usr/sbin/saslauthd -a pam -c -r -m /var/run/saslauthd -t 1800 -n 5
├─491932 /usr/sbin/saslauthd -a pam -c -r -m /var/run/saslauthd -t 1800 -n 5
Once the service is running, Postfix can connect to the SASL authentication socket and mail clients can successfully authenticate via Secure SMTP.
