You get an traceback while using samba-tool
samba-tool user list
ERROR(runtime): uncaught exception - Unable to load default file
File "/usr/lib/python3/dist-packages/samba/netcmd/__init__.py", line 186, in _run
return self.run(*args, **kwargs)
File "/usr/lib/python3/dist-packages/samba/netcmd/user.py", line 488, in run
lp = sambaopts.get_loadparm()
File "/usr/lib/python3/dist-packages/samba/getopt.py", line 92, in get_loadparm
self._lp.load_default()
And in the samba log under /var/log/samba/log.samba you find some like
/usr/sbin/samba_dnsupdate: RuntimeError: Unable to load file /etc/samba/smb.conf
[2023/04/11 08:22:59.958045, 0, pid=16619] ../../source4/dsdb/dns/dns_update.c:86(dnsupdate_nameupdate_done)
dnsupdate_nameupdate_done: Failed DNS update with exit code 1
Solution for configs
You will find several configs under /etc/samba/local.config.conf
less /etc/samba/local.config.conf
include = /etc/samba/local.config.d/global.local.config.conf
include = /etc/samba/local.config.d/printer.local.config.conf
include = /etc/samba/local.config.d/printer.epsonxyz.local.config.conf
include = /etc/samba/local.config.d/printer.brotherxyz.local.config.conf
Check if they exist one by one, for example:
ls -lah /etc/samba/local.config.d/global.local.config.conf
If you get one config that’s not exist:
ls -lah /etc/samba/local.config.d/printer.local.config.conf
ls: access to ‘/etc/samba/local.config.d/printer.local.config.conf’ not possible: File or directory not found
Uncomment the config with an # and restart the samba
#include = /etc/samba/local.config.d/printer.local.config.conf
/etc/inid.d/samba restart
Solution for Shares
Furthermore there is the path for shares there can also be configs that are no longer exist.
/etc/samba/shares.conf
Same check here like
less /etc/samba/shares.conf
include = /etc/samba/shares.conf.d/sharename
include = /etc/samba/shares.conf.d/example-name
include = /etc/samba/shares.conf.d/example-share
also check them with:
ls -lah /etc/samba/shares.conf.d/example-share>
ls: access to ‘/etc/samba/shares.conf.d/example-share’ not possible: File or directory not found
Same thing here, uncomment the none existing shares with an #
#include = /etc/samba/shares.conf.d/example-share
And just restart the samba service
