Problem: Samba-Shares - Group Members cannot access Samba Shares
A shared folder has been created and permissions allocated, but members of the designated group cannot access the folder.
Cause:
This issue commonly arises when the Samba share is configured by manually editing /etc/samba/smb.conf instead of using the Univention Management Console (UMC) or Univention Configuration Registry (UCR). In Univention Corporate Server (UCS), direct modifications to configuration files are not persistent. The system uses a template-based approach where UCR variables generate active configuration files. Manual changes may be overwritten during updates or when UCR variables are committed, leading to inconsistent access rights.
1. Revert Manual smb.conf Changes and Regenerate Configuration
To ensure a consistent configuration:
  1. Revert any manual modifications by regenerating smb.conf from UCR templates:
    ucr commit /etc/samba/smb.conf
  2. Restart the Samba service to apply the changes:
    /etc/init.d/samba restart
2. Correctly Create and Manage Samba Shares via UMC
Use the Univention Management Console to manage shares and permissions consistently:
  1. Log in to the UMC and navigate to Domain > Shares.
  2. Select the share and click Edit, or create a new share if necessary.
  3. In the General tab:
    • Verify the Directory owner group (e.g., “Domain Users”) and basic permissions.
  4. In the Samba Permissions tab:
    • Ensure the correct users or groups are listed in valid users/groups (groups prefixed with @).
    • Enable Samba write access and Users with write access may modify permissions, if required.
  5. Under Advanced settings > Samba extended permissions:
    • Enable NT ACL support and Inherit ACLs for Windows-style permission management.
For detailed guidance, refer to the UCS Manual, “File share management” and specifically 12.2.3 Shares UMC module – Samba tab:
https://docs.software-univention.de/manual/5.2/en/shares/index.html
Note: Only use UMC for configuring the root directory of a share. Direct filesystem edits will be overwritten by UCS.
3. Further Troubleshooting (if issues persist):
  • Verify AD-compatible Domain Controller: Ensure the “AD-compatible Domaincontroller” app is installed via UMC AppCenter.
  • Check Linux File System Permissions (POSIX ACLs): Even with correct Samba permissions, restrictive POSIX ACLs may block access:
    getfacl <path>
  • Validate Samba Configuration:
    testparm -s
  • Test Share Access from Server:
    smbclient //localhost/<sharename> -U <username>%<password>
  • Review Log Files:
    • Samba logs: /var/log/samba/log.samba, /var/log/samba/log.smbd, /var/log/samba/log.nmbd
    • UCS logs: /var/log/univention/
References:
