When using the samba-tool to set the pwdMaxAge in Samba back to 0 the internal value is -9223372036854775808. That value than is synced to UCS/OpenLDAP but the S4 connector rejects the change and the Impact is, a new created user could not be moved in an other container.
/var/log/univention/connector-s4.log shows:
27.03.2025 10:25:20.322 LDAP (PROCESS): sync AD > UCS: Resync rejected dn: 'DC=domain,DC=internal'
27.03.2025 10:25:20.328 LDAP (PROCESS): sync AD > UCS: [ container_dc] [ modify] 'dc=domain,dc=internal'
27.03.2025 10:25:20.330 LDAP (ERROR ): InvalidSyntax: Invalid syntax: Maximum password age: Value out of bounds (0 - 86313600 seconds). ('dc=domain,dc=internal')
27.03.2025 10:26:15.665 LDAP (PROCESS): sync AD > UCS: Resync rejected dn: 'DC=domain,DC=internal'
27.03.2025 10:26:15.671 LDAP (PROCESS): sync AD > UCS: [ container_dc] [ modify] 'dc=domain,dc=internal'
27.03.2025 10:26:15.672 LDAP (ERROR ): InvalidSyntax: Invalid syntax: Maximum password age: Value out of bounds (0 - 86313600 seconds). ('dc=domain,dc=internal')
27.03.2025 10:27:11.034 LDAP (PROCESS): sync AD > UCS: Resync rejected dn: 'DC=domain,DC=internal'
27.03.2025 10:27:11.039 LDAP (PROCESS): sync AD > UCS: [ container_dc] [ modify] 'dc=domain,dc=internal'
27.03.2025 10:27:11.040 LDAP (ERROR ): InvalidSyntax: Invalid syntax: Maximum password age: Value out of bounds (0 - 86313600 seconds). ('dc=domain,dc=internal')
By modifying the setting from the sambadbomain, the correct value is adopted and the S4-Connector then resolves the reject.
udm settings/sambadomain modify --dn "sambaDomainName=$(ucr get windows/domain),cn=samba,$(ucr get ldap/base)" --set maxPasswordAge=1 -
udm settings/sambadomain modify --dn "sambaDomainName=$(ucr get windows/domain),cn=samba,$(ucr get ldap/base)" --set maxPasswordAge=0
Root Cause
Bug-Report 47876
univention-s4search maxPwdAge=* 1.1 maxPwdAge
# record 1
dn: DC=domain,DC=internal
maxPwdAge: -9223372036854775808
udm policies/pwhistory list
DN: cn=default-settings,cn=pwhistory,cn=users,cn=policies,dc=domain,dc=internal
expiryInterval: None
ldapFilter: None
length: 3
pwLength: 8
pwQualityCheck: None
DN: cn=Passwort_10_Zeichen,cn=policies,dc=domain,dc=internal
expiryInterval: 730
ldapFilter: None
length: 1
pwLength: 10
pwQualityCheck: TRUE
udm settings/sambadomain list
DN: sambaDomainName=SEP,cn=samba,dc=domain,dc=internal
NextGroupRid: 1000
NextRid: None
NextUserRid: 1000
SID: S-1-5-21-2070111880-1463812749-1768392224
badLockoutAttempts: None
disconnectTime: None
domainPasswordComplex: 1
domainPasswordStoreCleartext: 0
domainPwdProperties: 1
lockoutDuration: None
logonToChangePW: None
maxPasswordAge: None
minPasswordAge: None
passwordHistory: 0
passwordLength: 8
refuseMachinePWChange: None
resetCountMinutes: None
