S4 Connector Rejects Due to LDAP Constraint Violation on objectSid
Problem Description:
In a UCS environment with a primary (ucs5primary) and a replica (ucs5replica) DC, the S4 Connector reported rejects due to unsynchronized objects. The primary DC object could not be added or modified in Active Directory because of a unique SID conflict, causing constraint violations. Investigation revealed that the replica’s objectSid in Samba did not match its LDAP sambaSID, resulting in rejected synchronization attempts and errors in the connector logs.
Key Points:
- UCS primary and replica DCs exist in the same domain.
- S4 Connector rejects occurred for the primary DC (
ucs5primary). - Connector logs indicate
CONSTRAINT_VIOLATIONdue toobjectSidduplication. - Replica DC’s Samba
objectSiddid not match its LDAP entry, preventing proper synchronization.
UCS Version: 5.x
Affected Hosts:
- UCS Primary DC:
ucs5primary - UCS Replica:
ucs5replica
Error in the system diagnostic module:
During S4 Connector checks, the following error appears:
############################# Start 43_connectors4_rejects ############################
## Check failed: 43_connectors4_rejects - Nicht synchronisierte S4 Connector Objekte ##
1 nicht synchronisierte UCS Objekte und 0 nicht synchronisierte S4 Objekte. Weitere Hinweise finden Sie unter Univention Support Database - Wie mit S4-Connector Konflikten umgehen (https://help.univention.com/t/how-to-deal-with-s4-connector-rejects/33).
Nicht synchronisierte UCS Objekte:
UCS DN: cn=ucs5primary,cn=dc,cn=computers,dc=example,dc=com, S4 DN: nicht gefunden, Dateiname: /var/lib/univention-connector/s4/1760525315.836549
############################## End 43_connectors4_rejects #############################
Rejected Objects List:
root@ucs5replica:~/univention-support# univention-s4connector-list-rejected
UCS rejected
1: UCS DN: cn=ucs5primary,cn=dc,cn=computers,dc=example,dc=com
S4 DN: <not found>
Filename: /var/lib/univention-connector/s4/1760525315.836549
2: UCS DN: cn=ucs5primary,cn=dc,cn=computers,dc=example,dc=com
S4 DN: <not found>
Filename: /var/lib/univention-connector/s4/1760915154.325939
3: UCS DN: cn=ucs5primary,cn=dc,cn=computers,dc=example,dc=com
S4 DN: <not found>
Filename: /var/lib/univention-connector/s4/1760915169.653103
Connector-s4 Log:
/var/log/univention/connector-s4.log
15.10.2025 12:59:29.285 LDAP (PROCESS): sync UCS > AD: [ dc] [ add] 'cn=ucs5primary,ou=Domain Controllers,DC=EXAMPLE,DC=COM'
15.10.2025 12:59:29.290 LDAP (PROCESS): sync_from_ucs: error during add, searching for conflicting deleted object in S4
15.10.2025 12:59:29.291 LDAP (PROCESS): sync_from_ucs: no conflicting deleted object found
15.10.2025 12:59:29.293 LDAP (WARNING): sync failed, saved as rejected
15.10.2025 12:59:29.293 LDAP (WARNING): Traceback (most recent call last):
File "/usr/lib/python3/dist-packages/univention/s4connector/__init__.py", line 828, in __sync_file_from_ucs
if not self.sync_from_ucs(key, mapped_object, pre_mapped_ucs_dn, old_dn, old, new):
File "/usr/lib/python3/dist-packages/univention/s4connector/s4/__init__.py", line 2070, in sync_from_ucs
self.lo_s4.lo.add_ext_s(object['dn'], addlist, serverctrls=ctrls)
File "/usr/lib/python3/dist-packages/ldap/ldapobject.py", line 414, in add_ext_s
File "/usr/lib/python3/dist-packages/ldap/ldapobject.py", line 749, in result3
File "/usr/lib/python3/dist-packages/ldap/ldapobject.py", line 756, in result4
File "/usr/lib/python3/dist-packages/ldap/ldapobject.py", line 329, in _ldap_call
reraise(exc_type, exc_value, exc_traceback)
File "/usr/lib/python3/dist-packages/ldap/compat.py", line 44, in reraise
raise exc_value
File "/usr/lib/python3/dist-packages/ldap/ldapobject.py", line 313, in _ldap_call
result = func(*args,**kwargs)
ldap.CONSTRAINT_VIOLATION: {'desc': 'Constraint violation', 'info': 'unique index violation on objectSid in CN=ucs5primary,OU=Domain Controllers,DC=example,DC=com'}
Investigation:
Commands and output on primary host:
root@ucs5primary:~/univention-support# univention-ldapsearch cn=ucs5primary sambaSID -LLL
dn: cn=ucs5primary,cn=dc,cn=computers,dc=example,dc=com
sambaSID: S-1-5-21-262092250-3554280320-960752464-1000
root@ucs5primary:~/univention-support# univention-s4search cn=ucs5primary objectSid
dn: CN=UCS5PRIMARY,OU=Domain Controllers,DC=example,DC=com
objectSid: S-1-5-21-262092250-3554280320-960752464-1000
root@ucs5primary:~/univention-support# univention-ldapsearch cn=ucs5replica sambaSID -LLL
dn: cn=ucs5replica,cn=dc,cn=server,cn=computers,ou=FSGE,dc=example,dc=com
sambaSID: S-1-5-21-262092250-3554280320-960752464-51946
root@ucs5primary:~/univention-support# univention-s4search cn=ucs5replica objectSid
dn: CN=UCS5REPLICA,OU=Domain Controllers,DC=example,DC=com
Additional checks from replica host:
root@ucs5replica:~/univention-support# univention-ldapsearch cn=ucs5primary sambaSID -LLL
root@ucs5replica:~/univention-support# univention-ldapsearch cn=ucs5replica sambaSID -LLL
root@ucs5replica:~/univention-support# univention-s4search cn=ucs5replica objectSid
Disclaimer
Warning: This procedure involves direct modifications of the Samba backend.
No automatic validation is performed. Manual edits to the Samba database entries must be performed carefully and conscientiously to avoid inconsistencies or data loss.
Correct the SID of the replica in Samba using via ldbedit:
ldbedit -H /var/lib/samba/private/sam.ldb --controls=provision:0 --controls=local_oid:1.3.6.1.4.1.7165.4.3.3:0 -b "CN=UCS5REPLICA,OU=Domain Controllers,DC=example,DC=com"
Set objectSid to match UCS sambaSID:
objectSid: S-1-5-21-262092250-3554280320-960752464-51946
Verification
24.10.2025 15:49:19.103 LDAP (PROCESS): sync AD > UCS: [dc] [modify] 'cn=ucs5replica,cn=dc,cn=server,cn=computers,ou=fsge,dc=example,dc=com'
24.10.2025 15:49:36.775 MAIN (------ ): DEBUG_INIT
24.10.25 15:49:36.775 DEBUG_INIT
24.10.25 15:49:36.799 DEBUG_EXIT
24.10.2025 15:50:10.365 LDAP (PROCESS): sync UCS > AD: Resync rejected file: /var/lib/univention-connector/s4/1760525315.836549
24.10.2025 15:50:10.367 LDAP (PROCESS): sync UCS > AD: [dc] [add] 'cn=ucs5primary,ou=Domain Controllers,DC=EXAMPLE,DC=COM'
24.10.2025 15:50:10.404 LDAP (PROCESS): sync UCS > AD: Resync rejected file: /var/lib/univention-connector/s4/1760915154.325939
24.10.2025 15:50:10.406 LDAP (PROCESS): sync UCS > AD: [dc] [modify] 'cn=ucs5primary,ou=domain controllers,DC=example,DC=com'
24.10.2025 15:50:10.413 LDAP (PROCESS): sync UCS > AD: Resync rejected file: /var/lib/univention-connector/s4/1760915169.653103
24.10.2025 15:50:10.414 LDAP (PROCESS): sync UCS > AD: [dc] [modify] 'cn=ucs5primary,ou=domain controllers,DC=example,DC=com'
24.10.2025 15:50:15.447 LDAP (PROCESS): sync AD > UCS: [dc] [modify] 'cn=ucs5primary,cn=dc,cn=computers,dc=example,dc=com'
24.10.2025 15:50:19.639 MAIN (------ ): DEBUG_INIT
24.10.25 15:50:19.639 DEBUG_INIT
24.10.25 15:50:19.664 DEBUG_EXIT
UCS rejected
S4 rejected
There may be no rejected DNs if the connector is in progress, to be
sure stop the connector before running this script.
last synced USN: 8933
root@ucs5replica:~/univention-support# univention-s4search cn=ucs5primary dn objectSid
# record 1
dn: CN=ucs5primary,OU=Domain Controllers,DC=example,DC=com
root@ucs5replica:~/univention-support# univention-s4search cn=ucs5replica dn objectSid
# record 1
Result
S4 Connector rejects for the DC master ucs5primary were resolved after correcting the replica objectSid. No rejected objects remain.
