Resolving Windows Client Trust Relationship Issues with Samba AD
When attempting to log in to a Windows client that is joined to a Samba Active Directory (AD) domain, you may encounter the following error message:
“The security database on the server does not have a computer account for this workstation trust relationship.”
This indicates that the trust relationship between the affected Windows client and the samba domain is broken.
Solutions:
There are two recommended approaches to resolve this issue: repairing the trust relationship or rejoining the domain.
Option 1: Repair the Trust Relationship via PowerShell
Log in to the affected Windows client with a local administrator account.
Open PowerShell with administrative privileges.
Test the trust relationship by running:
Test-ComputerSecureChannel -Verbose- Output
True→ The trust relationship is intact. - Output
False→ The trust relationship is broken.
- Output
If the trust is broken, repair it using:
Test-ComputerSecureChannel -Repair -Credential (Get-Credential)Or specify the domain controller explicitly:
Test-ComputerSecureChannel -Repair -Server master.example-school.loc -Credential AdministratorYou will be prompted for domain administrator credentials. The system will attempt to synchronize the computer account with the domain controller.
Advantages:
- No need to leave and rejoin the domain.
- Existing user profiles remain intact.
Disadvantages:
- May not work if the computer account in the Samba DB is severely corrupted.
Option 2: Rejoin the Domain
If the repair fails, rejoining the domain is necessary:
Log in with a local administrator account.
Remove the computer from the domain:
- Right-click This PC → Properties → Advanced system settings → Computer Name.
- Click Change….
- Select Workgroup and enter, for example,
WORKGROUP. - Restart the computer.
Rejoin the computer to the domain
example-school.loc. -
Provide domain administrator credentials when prompted.
Restart the computer to apply changes.
Reference: Windows domain joins
Note: Always ensure that domain controllers are reachable and that network connectivity is stable before performing these steps.
