Provisioning - Prefill fails in large environments - prefill_queue_status":"failed"
In a large school environment with 100,000 or more users, the Prefill service may fail because of a timeout while querying the UDM REST API.
The issue occurs because the service attempts to load all Distinguished Names (DNs) of a UDM module in a single request.
Output
root@ucs5primary:~/univention-support# curl -k -X GET -u "example-consumer:SoM3-reA1ly_sEc4eT_Pa33morD" "https://localhost/univention/provisioning/v1/subscriptions/example-consumer"
{"name":"example-consumer","realms_topics":[{"realm":"udm","topic":"users/user"}],"request_prefill":true,"prefill_queue_status":"failed"}
Check the Prefill service logs:
docker logs nubus-provisioning-prefill
2026-06-29 14:30:57,713 ERROR [None] [prefill_service.handle_requests_to_prefill:83] Unknown error occurred while processing the prefill request.
+ Exception Group Traceback (most recent call last):
| File "/app/prefill/.venv/lib/python3.11/site-packages/univention/provisioning/prefill/prefill_service.py", line 68, in handle_requests_to_prefill
| await self.ack_manager.process_message_with_ack_wait_extension(
| File "/app/prefill/.venv/lib/python3.11/site-packages/univention/provisioning/backends/message_queue.py", line 169, in process_message_with_ack_wait_extension
| async with asyncio.TaskGroup() as task_group:
| File "/usr/lib/python3.11/asyncio/taskgroups.py", line 133, in __aexit__
| raise me from None
| ExceptionGroup: unhandled errors in a TaskGroup (1 sub-exception)
+-+---------------- 1 ----------------
| File "/app/prefill/.venv/lib/python3.11/site-packages/aiohttp/client_reqrep.py", line 539, in start
| message, payload = await protocol.read() # type: ignore[union-attr]
| File "/app/prefill/.venv/lib/python3.11/site-packages/aiohttp/streams.py", line 703, in read
| await self._waiter
| asyncio.exceptions.CancelledError
| The above exception was the direct cause of the following exception:
| File "/app/prefill/.venv/lib/python3.11/site-packages/univention/provisioning/prefill/prefill_service.py", line 119, in handle_message
| await self._handle_message(validated_message)
| File "/app/prefill/.venv/lib/python3.11/site-packages/univention/provisioning/prefill/prefill_service.py", line 142, in _handle_message
| await self.fetch_udm(message.subscription_name, realm_topic.topic)
| File "/app/prefill/.venv/lib/python3.11/site-packages/univention/provisioning/prefill/prefill_service.py", line 160, in fetch_udm
| await self._fill_udm_topic(this_topic, subscription_name)
| File "/app/prefill/.venv/lib/python3.11/site-packages/univention/provisioning/prefill/prefill_service.py", line 181, in _fill_udm_topic
| urls = await self.udm.list_objects(object_type)
| File "/app/prefill/.venv/lib/python3.11/site-packages/tenacity/asyncio/__init__.py", line 193, in async_wrapped
| return await copy(fn, *args, **kwargs)
| File "/app/prefill/.venv/lib/python3.11/site-packages/tenacity/asyncio/__init__.py", line 112, in __call__
| do = await self.iter(retry_state=retry_state)
| File "/app/prefill/.venv/lib/python3.11/site-packages/tenacity/asyncio/__init__.py", line 157, in iter
| result = await action(retry_state)
| File "/app/prefill/.venv/lib/python3.11/site-packages/tenacity/_utils.py", line 111, in inner
| return call(*args, **kwargs)
| File "/app/prefill/.venv/lib/python3.11/site-packages/tenacity/__init__.py", line 393, in <lambda>
| self._add_action_func(lambda rs: rs.outcome.result())
| File "/usr/lib/python3.11/concurrent/futures/_base.py", line 449, in result
| return self.__get_result()
| File "/usr/lib/python3.11/concurrent/futures/_base.py", line 401, in __get_result
| raise self._exception
| File "/app/prefill/.venv/lib/python3.11/site-packages/tenacity/asyncio/__init__.py", line 116, in __call__
| result = await fn(*args, **kwargs)
| File "/app/prefill/.venv/lib/python3.11/site-packages/univention/provisioning/prefill/udm_adapter.py", line 89, in list_objects
| async with self._session.get(f"{self.base_url}{object_type}/", params=params) as request:
| File "/app/prefill/.venv/lib/python3.11/site-packages/aiohttp/client.py", line 1510, in __aenter__
| self._resp: _RetType = await self._coro
| File "/app/prefill/.venv/lib/python3.11/site-packages/aiohttp/client.py", line 779, in _request
| resp = await handler(req)
| File "/app/prefill/.venv/lib/python3.11/site-packages/aiohttp/client.py", line 757, in _connect_and_send_request
| await resp.start(conn)
| File "/app/prefill/.venv/lib/python3.11/site-packages/aiohttp/client_reqrep.py", line 534, in start
| with self._timer:
| File "/app/prefill/.venv/lib/python3.11/site-packages/aiohttp/helpers.py", line 713, in __exit__
| raise asyncio.TimeoutError from exc_val
| TimeoutError
2026-06-29 14:30:57,736 WARNING [None] [_daemonize_unix.__exit__:141] Daemonizer exited without calling daemonize.
| File "/app/prefill/.venv/bin/prefill", line 8, in <module>
| sys.exit(run())
| File "/app/prefill/.venv/lib/python3.11/site-packages/univention/provisioning/prefill/main.py", line 43, in run
| asyncio.run(main(settings))
| File "/usr/lib/python3.11/asyncio/runners.py", line 190, in run
| return runner.run(main)
| File "/usr/lib/python3.11/asyncio/runners.py", line 118, in run
| return self._loop.run_until_complete(task)
| File "/usr/lib/python3.11/asyncio/base_events.py", line 653, in run_until_complete
| return future.result()
| File "/app/prefill/.venv/lib/python3.11/site-packages/univention/provisioning/prefill/main.py", line 37, in main
| await service.handle_requests_to_prefill()
| raise me from None
| await self._waiter
| with self._timer:
| TimeoutError
/entrypoint.sh: No files found in /entrypoint.d/, skipping configuration
2026-06-29 11:50:56,710 ERROR [None] [prefill_service.handle_message:108] The maximum number of retries for prefilling the subscription %s has been reached. The prefill will not be retried again and the subscription will be marked as failed. To trigger the prefill again, delete and recreate the subscription.
Root Cause
The issue occurs with the following component versions:
- Provisioning-Service Version 2.1.0
- Provisioning-NATS Version 2.12
During a prefill, the service loads all DNs of a module in a single operation. This can result in an empty response and a 30-second NATS timeout.
Check the current NATS maximum payload:
root@ucs5primary:~/univention-support/substring# curl -s http://127.0.0.1:8222/varz | grep max_payload
"max_payload": 1048576,
The configured max_payload with 1MB is insufficient for larger environments containing 20,000 or 100,000 user objects because all DNs are retrieved at once during the prefill operation.
Investigation
Reproducing the issue
The issue was reproduced by creating 20,000 users for a school.
/usr/share/ucs-school-import/scripts/ucs-school-testuser-import --httpapi --students 20 --classes 2 <ou>
/usr/share/ucs-school-import/scripts/ucs-school-testuser-import --httpapi --students 20000 --teachers 100 --classes 2 Heisenberg
/usr/share/ucs-school-import/scripts/ucs-school-user-import --school 'Heisenberg' --user_role student --source_uid 'heisenberg-student' --conffile '/usr/share/ucs-school-import/configs/ucs-school-testuser-http-import.json' --infile 'test_users_2026-06-29_14:00:52.csv'
Check the NATS maximum payload:
Retrieve the nubus-provisioning-api credentials
root@ucs5primary:~/univention-support/substring# docker exec nubus-provisioning-api env | grep -i admin
ADMIN_NATS_USER=NOT_SET_NOT_REQUIRED
ADMIN_NATS_PASSWORD=NOT_SET_NOT_REQUIRED
ADMIN_USERNAME=admin
ADMIN_PASSWORD=pJoASmIEFKnhdWeH6fb8S0YAJUWPd7i4
Export the administrator credentials:
root@ucs5primary:~# export ADMIN_USERNAME=$(docker exec nubus-provisioning-api printenv ADMIN_USERNAME)
root@ucs5primary:~# export ADMIN_PASSWORD=$(docker exec nubus-provisioning-api printenv ADMIN_PASSWORD)
Dry run
root@ucs5primary:~# curl -k -X GET -u "$ADMIN_USERNAME:$ADMIN_PASSWORD" "https://localhost/univention/provisioning/v1/subscriptions"
[]root@ucs5primary:~#
Explanation
An empty array, [], indicates that no third-party system or consumer has yet been connected to the new Provisioning API.
Subscription configuration
root@ucs5primary:~/univention-support# cat provisioning-api.json
"name": "example-consumer",
"realms_topics": [
"realm": "udm",
"topic": "users/user"
"request_prefill": true,
"password": "SoM3-reA1ly_sEc4eT_Pa33morD"
Create the subscription
root@ucs5primary:~/univention-support# curl -k -X POST -u "$ADMIN_USERNAME":"$ADMIN_PASSWORD" "https://localhost/univention/provisioning/v1/subscriptions" -H "Content-Type: application/json" --data @provisioning-api.json
Check the subscription status:
{"name":"example-consumer","realms_topics":[{"realm":"udm","topic":"users/user"}],"request_prefill":true,"prefill_queue_status":"done"}
Workaround
Increase the max_payload value in the following file:
nano /var/lib/univention-appcenter/apps/provisioning-service/conf/nats.conf
Example configuration to reproduce the issue (max_payload is manually configured to 1KB):
server_name: nats
pid_file: "/nats.pid"
port: 4222
http_port: 8222
max_payload: 1000 <-- 1kb
lame_duck_duration: 30s
lame_duck_grace_period: 10s
jetstream {
max_file_store: 1Gi
max_memory_store: 256Mi
store_dir: "/data"
<skip>
Check the prefill with a dry run
The request fails because max_payload is configured to 1 KB. The previous default in this test was 1MB. A payload of 1 KB is too small for large environments containing 20,000 or more users.
root@ucs5primary:~/univention-support# curl -k -s -o /dev/null -w "\n=== DETAILLIERTE ZEITMESSUNG ===\nDNS-Auflösung: %{time_namelookup}s\nTCP-Verbindungsaufbau: %{time_connect}s\nTLS-Handshake: %{time_appconnect}s\nServer-Verarbeitung (LDAP + JSON): %{time_starttransfer}s\nGesamte Download-Dauer: %{time_total}s\n\nHTTP-Status: %{http_code}\nÜbertragene Datenmenge: %{size_download} Bytes\n" \
-u "provi-11650649$:4a9f048910581b185560eb979ecb48c7e3fddf7b075eead42910c3fe5f4f1485" \
"https://ucs5primary.miro.intranet/univention/udm/users/user/?scope=sub&hidden=true&properties=NonExistantDummyProperty&page=1&limit=0&dir=ASC"
DNS-Auflösung: 0.001280s
TCP-Verbindungsaufbau: 0.001428s
TLS-Handshake: 0.010115s
Server-Verarbeitung (LDAP + JSON): 311.028980s
Gesamte Download-Dauer: 311.029091s
HTTP-Status: 503
Übertragene Datenmenge: 117 Bytes
Delete the subscription
root@ucs5primary:~/univention-support# curl -k -X DELETE -u "example-consumer:SoM3-reA1ly_sEc4eT_Pa33morD" "https://localhost/univention/provisioning/v1/subscriptions/example-consumer"
null
root@ucs5primary:~/univention-support# curl -k -X GET -u "$ADMIN_USERNAME:$ADMIN_PASSWORD" "https://localhost/univention/provisioning/v1/subscriptions"
[{"name":"example-consumer","realms_topics":[{"realm":"udm","topic":"users/user"}],"request_prefill":true,"prefill_queue_status":"running"}]
After some time, the prefill_queue_status changes to failed:
[{"name":"example-consumer","realms_topics":[{"realm":"udm","topic":"users/user"}],"request_prefill":true,"prefill_queue_status":"failed"}]
| await self._waiter
| with self._timer:
| TimeoutError
Fixed in Version 2.2.0
This issue is fixed in Provisioning-Service Version 2.2.0.
Verify the deployed container versions:
root@ucs5primary:~# docker ps
CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES
eaa7538a44ab artifacts.software-univention.de/nubus/images/provisioning-dispatcher:2.2.0 "tini -- /entrypoint…" 31 seconds ago Up 31 seconds nubus-provisioning-dispatcher
e7e7a6cd67d0 artifacts.software-univention.de/nubus/images/provisioning-prefill:2.2.0 "tini -- /entrypoint…" 31 seconds ago Up 31 seconds nubus-provisioning-prefill
651a5354bb2d artifacts.software-univention.de/nubus/images/provisioning-udm-transformer:2.2.0 "tini -- /entrypoint…" 32 seconds ago Up 31 seconds nubus-provisioning-udm-transformer
75f9011b906a artifacts.software-univention.de/nubus/images/provisioning-api:2.2.0 "tini -- /entrypoint…" 32 seconds ago Up 31 seconds 0.0.0.0:40000->7777/tcp, :::40000->7777/tcp nubus-provisioning-api
3cd99161c4c4 artifacts.software-univention.de/library/nats:2.14.3 "/nats-server -c /ru…" 33 seconds ago Up 32 seconds 0.0.0.0:4222->4222/tcp, :::4222->4222/tcp, 0.0.0.0:8222->8222/tcp, :::8222->8222/tcp, 6222/tcp provisioning-service_nats_1
Check the updated NATS maximum payload to 16MB:
root@ucs5primary:~# curl -s http://127.0.0.1:8222/varz | grep max_payload
"max_payload": 16777216,
Check the UDM connection configuration of the Prefill container:
root@ucs5primary:~# docker exec nubus-provisioning-prefill env | grep -i udm
UDM_HOST=ucs5primary.univention.intranet
UDM_PORT=443
UDM_URL_PATH_PREFIX=/univention
UDM_PROTOCOL=https
UDM_USERNAME=ucs5primary$
UDM_PASSWORD=4aIH07nfJCvd6EPyX5SK
Verify the UDM REST API request:
-H "Accept: application/json" \
-u "ucs5primary\$:4aIH07nfJCvd6EPyX5SK" \
"https://ucs5primary.univention.intranet/univention/udm/users/user/?scope=sub&hidden=true&properties=NonExistantDummyProperty&page=1&limit=0&dir=ASC"
DNS-Auflösung: 0.000444s
TCP-Verbindungsaufbau: 0.000531s
TLS-Handshake: 0.004914s
Server-Verarbeitung (LDAP + JSON): 27.346697s
Gesamte Download-Dauer: 27.401551s
HTTP-Status: 200
Übertragene Datenmenge: 19756964 Bytes
Check the subscription configuration:
root@ucs5primary:~# cat provisioning-api.json
"realms_topics": [
"realm": "udm",
Delete the existing subscription:
root@ucs5primary:~# curl -k -X DELETE -u "example-consumer:SoM3-reA1ly_sEc4eT_Pa33morD" "https://localhost/univention/provisioning/v1/subscriptions/example-consumer"
Recreate the subscription:
root@ucs5primary:~# curl -k -X POST -u "$ADMIN_USERNAME":"$ADMIN_PASSWORD" "https://localhost/univention/provisioning/v1/subscriptions" -H "Content-Type: application/json" --data @provisioning-api.json
null
The subscription initially has the status running:
root@ucs5primarycurl -k -X GET -u "$ADMIN_USERNAME:$ADMIN_PASSWORD" "https://localhost/univention/provisioning/v1/subscriptions"ons"
After the prefill completes, the status changes to done:
[{"name":"example-consumer","realms_topics":[{"realm":"udm","topic":"users/user"}],"request_prefill":true,"prefill_queue_status":"done"}]
The issue is fixed in Provisioning-Service Version 2.2.0. Upgrade the Provisioning Service to the latest available version:
univention-app update
univention-app upgrade provisioning-service
