The Prometheus app on the Primary Domain Controller (DC) is using a significant amount of disk space:
# du -shx /var/lib/univention-appcenter/apps/prometheus/data
22G /var/lib/univention-appcenter/apps/prometheus/data
Is a 22 GB Prometheus data directory normal? Can the storage usage be optimized?
Root Cause
Prometheus stores time-series data locally on disk. The storage size depends heavily on:
- Number of monitored hosts or services
- Scraping interval (how often metrics are collected)
- Data retention period (how long metrics are kept)
A 22 GB data directory is not unusual in environments where multiple hosts are being monitored or where detailed metrics are collected at frequent intervals.
In smaller setups, typical usage ranges between 1–5 GB, but this increases quickly with larger domains or shorter scrape intervals.
To optimize storage usage, you can adjust Prometheus’ configuration parameters directly through the Univention App Center.
Run the following command to list available options:
univention-app configure prometheus --list
Key parameters to review:
prometheus/storage/tsdb/retention
Defines how long Prometheus keeps historical data (default:15d).
Reducing this value will decrease disk usage. -
scrape/interval
Controls how often metrics are collected (default:1m).
Increasing this interval (e.g., to2mor5m) can significantly reduce data volume. -
prometheus/generic/server/parameters
Allows passing additional flags to Prometheus.
You can limit disk usage by setting a fixed maximum size, for example:--storage.tsdb.retention.size=10GBThis will cap Prometheus’ storage to 10 GB regardless of the retention time.
For a detailed explanation of how retention settings and size limits interact, see the following article:
Configuring Prometheus storage retention (robustperception.io)
