DRAFT!
The UMC diagnostic module reports problems with UDN replication:
There might be similar symptoms referring to a failing replication. The solution should apply.
Environment
This solution only applies to UCS starting from version 4.3-3 errata427. For earlier versions please refer to this article.
Step 1
First, we will check if the transaction file itself has corrupt entries or is otherwise broken.
Step 1a
Create the following script and name it “transaction_check.py”:
#!/usr/bin/env python
with open('/var/lib/univention-ldap/notify/transaction', 'r') as transaction:
lc = 1
for line in transaction:
(head, tail) = line.strip().split(' ', 1)
try:
cur_lc = int(head)
except ValueError:
print 'ERROR at line %d: "%s"' % (lc, line)
break
if len(tail.rsplit(' ', 1)) != 2:
print 'ERROR missing third column at line %d: "%s"' % (lc, line)
break
if cur_lc != lc:
print 'ERROR numbers not in order at line %d: "%s"' % (lc, line)
break
lc += 1
Step 1b
Execute the script by:
python transaction_check.py
It will output the first line where an error in the file appears.
Step 2
Identify the errors and fix them.
Step 2a
Note: The following commands will bring the OpenLDAP service down for a while. Consider to perform these steps during maintenance time if possible.
Re-enumerate the transactions by the following commands:
systemctl stop univention-directory-notifier
systemctl stop univention-directory-listener
systemctl stop slapd
# Now re-enumerate the transaction file:
cd /var/lib/univention-ldap/notify
cut -d ' ' -f 2- transaction | awk '{print NR " " $0}' > transaction.new
mv transaction transaction.bak
mv transaction.new transaction
rm -f transaction.index
# And set last_id to the last value:
tail -n 1 transaction | awk '{print $1}' > /var/lib/univention-ldap/last_id
systemctl start univention-directory-notifier
systemctl start slapd
systemctl start univention-directory-listener
