Problem: Portal-preview was installed -> how to update to UCS5
Portal-preview was installed → how to update to UCS5
Environment (optional)
UCS 4.4-x to UCS5 with portal-preview installed
Caution
The portal is emtpy after that procedure, but system is updated to UCS5 although portal-preview was installed. You must create the portal entries manually.
Step1: Start Upgrade
Your system has to be on 4.4-9 latest errata.
univention-upgrade
Step2: Remove portal_preview from repo
univention-app register univention-portal --undo-it
Step3: Change version on some ldap objects cause of upgrade errors
udm settings/ldapacl modify --dn "cn=62univention-portal,cn=ldapacl,cn=univention,$(ucr get ldap/base)" --set ucsversionstart=4.4-1 --set ucsversionend=5.99-0 ; \
udm settings/udm_syntax modify --dn "cn=univention-portal,cn=udm_syntax,cn=univention,$(ucr get ldap/base)" --set ucsversionstart=4.4-1 --set ucsversionend=5.99-0 ; \
udm settings/udm_module modify --dn "cn=portals/portal,cn=udm_module,cn=univention,$(ucr get ldap/base)" --set ucsversionstart=4.4-1 --set ucsversionend=5.99-0 ; \
udm settings/udm_module modify --dn "cn=portals/category,cn=udm_module,cn=univention,$(ucr get ldap/base)" --set ucsversionstart=4.4-1 --set ucsversionend=5.99-0 ; \
udm settings/udm_module modify --dn "cn=portals/entry,cn=udm_module,cn=univention,$(ucr get ldap/base)" --set ucsversionstart=4.4-1 --set ucsversionend=5.99-0 ; \
udm settings/udm_module modify --dn "cn=portals/folder,cn=udm_module,cn=univention,$(ucr get ldap/base)" --set ucsversionstart=4.4-1 --set ucsversionend=5.99-0 ; \
udm settings/udm_module modify --dn "cn=portals/all,cn=udm_module,cn=univention,$(ucr get ldap/base)" --set ucsversionstart=4.4-1 --set ucsversionend=5.99-0
Step4: Delete portal entry container
udm container/cn remove --dn "cn=portals,cn=univention,$(ucr get ldap/base)"
Finaly restart the upgrade to 5.0 and reboot the server
univention-upgrade
reboot
Mastodon
