New groups in UCS, although defined as an OX Group, cannot be selected within the Open-Xchange (OX) frontend. The specific example group mentioned by the customer was not present in the OX Context, indicating it was not provisioned correctly.
Root Cause
The groups were not assigned a mail address, which is a prerequisite for them to be displayed in the Open-Xchange frontend. Once a mail address was entered for the groups, they became visible.
Reference: https://forge.univention.org/bugzilla/show_bug.cgi?id=58580
Reproduce
Full notes from my tests:
Issue:
Existing groups and newly created groups are not synchronized to Open-Xchange, even though these groups are members in Context 10 and have isOxGroup=OK. (Note: The user objects are members in Context 10 with isOxUser=OK).
Environment:
root@ucs5primary:~# univention-app info
UCS: 5.2-2 errata180
Installed: dhcp-server=16.0 fetchmail=6.4.37 mailserver=16.0 oxseforucs=7.10.6-ucs11 samba4=4.21 self-service=7.0 self-service-backend=7.0 ucsschool=5.2v3 5.0/keycloak=25.0.6-ucs4 5.0/ox-connector=2.3.4
Upgradable: keycloak ox-connector
Steps to Reproduce:
Create a new group via UMC:
cn=Test-Gruppe-01- Set
isOxGroup=Ok. - Do not add any users to the group initially.
Listener Logs (Group Creation):
==> /var/log/univention/listener.log <== 02.09.25 11:27:07.442 LDAP ( PROCESS ) : connecting to ldap://ucs5primary.miro.intranet:7389 02.09.25 11:27:07.499 LISTENER ( PROCESS ) : updating 'cn=Test-Gruppe-01,cn=groups,dc=miro,dc=intranet' command a 02.09.25 11:27:08.260 LISTENER ( PROCESS ) : samba4-idmap: added entry for S-1-5-21-3450543618-4260802429-757627796-11185 ==> /var/log/univention/listener_modules/ox-connector.log <== 2025-09-02 11:27:08 INFO create of cn=Test-Gruppe-01,cn=groups,dc=miro,dc=intranet (id: b'bd4081a4-1c2a-1040-8369-877d70335bf4', file: /var/lib/univention-appcenter/listener//ox-connector/2025-09-02-11-27-08-270731.json) ==> /var/log/univention/listener.log <== 02.09.25 11:27:08.406 LISTENER ( PROCESS ) : ox-connector: create of cn=Test-Gruppe-01,cn=groups,dc=miro,dc=intranet (id: b'bd4081a4-1c2a-1040-8369-877d70335bf4', file: /var/lib/univention-appcenter/listener//ox-connector/2025-09-02-11-27-08-270731.json) 02.09.25 11:27:08.425 LISTENER ( PROCESS ) : updating 'cn=gidNumber,cn=temporary,cn=univention,dc=miro,dc=intranet' command m ==> /var/log/univention/listener_modules/ox-connector.log <== 2025-09-02 11:27:14 INFO Using App account connection 2025-09-02 11:27:14 INFO conversion of cn=Test-Gruppe-01,cn=groups,dc=miro,dc=intranet (id: bd4081a4-1c2a-1040-8369-877d70335bf4, file: /var/lib/univention-appcenter/apps/ox-connector/data/listener/2025-09-02-11-27-08-270731.json) 2025-09-02 11:27:16 INFO Handling PosixPath('/var/lib/univention-appcenter/apps/ox-connector/data/listener/2025-09-02-11-27-08-270731.json') 2025-09-02 11:27:16 INFO Group Test-Gruppe-01 will be OX Group 2025-09-02 11:27:16 INFO mv /var/lib/univention-appcenter/apps/ox-connector/data/listener/2025-09-02-11-27-08-270731.json -> /var/lib/univention-appcenter/apps/ox-connector/data/listener/old/bd4081a4-1c2a-1040-8369-877d70335bf4.json 2025-09-02 11:27:16 INFO Successfully processed 1 files during this run 2025-09-02 11:27:16 INFO Successfully processed 0 files during this run 2025-09-02 11:27:16 INFO Success! Removing consumed files ==> /var/log/univention/listener.log <== Updating default Portal data updated in 0.03s Updating selfservice Portal data untouched Updating umc Portal data untouched ==> /var/log/open-xchange/open-xchange.log.0 <== 2025-09-02T11:29:47,060+0200 INFO [OXTimer-0000433] com.openexchange.monitoring.impl.internal.memory.MemoryMonitoring.run(MemoryMonitoring.java:137) Garbage collection consumed 0.0% of uptime within 5 minutes. All fine. 2025-09-02T11:29:51,445+0200 INFO [com.openexchange.chronos.alarm.message.impl.MessageAlarmDeliveryWorker] com.openexchange.chronos.alarm.message.impl.MessageAlarmDeliveryWorker.prepareCleanUp(MessageAlarmDeliveryWorker.java:129) Started alarm delivery worker run... 2025-09-02T11:29:51,455+0200 INFO [com.openexchange.chronos.alarm.message.impl.MessageAlarmDeliveryWorker] com.openexchange.database.internal.GlobalDbInit.getGroupsByPool(GlobalDbInit.java:261) No pool identifier defined at section "default", ignoring global database section com.openexchange.database.schema=localhost_5 2025-09-02T11:29:51,469+0200 INFO [com.openexchange.chronos.alarm.message.impl.MessageAlarmDeliveryWorker] com.openexchange.database.cleanup.impl.CleanUpJobRunnable.cleanUp(CleanUpJobRunnable.java:204) Clean-up by job 'com.openexchange.chronos.alarm.message.impl.MessageAlarmDeliveryWorker' took 24ms (24ms) com.openexchange.database.schema=localhost_5 2025-09-02T11:29:51,469+0200 INFO [com.openexchange.chronos.alarm.message.impl.MessageAlarmDeliveryWorker] com.openexchange.chronos.alarm.message.impl.MessageAlarmDeliveryWorker.finishCleanUp(MessageAlarmDeliveryWorker.java:135) Alarm delivery worker run finished! com.openexchange.database.schema=localhost_5 - Set
Create user
Test OX-01(This user is required to be a member of the group later).Listener Logs (User Creation):
==> /var/log/univention/listener.log <== 02.09.25 11:34:38.428 LDAP ( PROCESS ) : connecting to ldap://ucs5primary.miro.intranet:7389 02.09.25 11:34:38.449 LISTENER ( PROCESS ) : updating 'uid=test.ox-01,cn=users,dc=miro,dc=intranet' command a 02.09.25 11:34:38.458 LISTENER ( PROCESS ) : samba4-idmap: added entry for S-1-5-21-3450543618-4260802429-757627796-5088 ==> /var/log/univention/listener_modules/ox-connector.log <== 2025-09-02 11:34:38 INFO create of uid=test.ox-01,cn=users,dc=miro,dc=intranet (id: b'ca15f39a-1c2b-1040-8372-877d70335bf4', file: /var/lib/univention-appcenter/listener//ox-connector/2025-09-02-11-34-38-458868.json) ==> /var/log/univention/listener.log <== 02.09.25 11:34:38.459 LISTENER ( PROCESS ) : ox-connector: create of uid=test.ox-01,cn=users,dc=miro,dc=intranet (id: b'ca15f39a-1c2b-1040-8372-877d70335bf4', file: /var/lib/univention-appcenter/listener//ox-connector/2025-09-02-11-34-38-458868.json) ... (omitted logs for Domain Users group update and connection details) ==> /var/log/open-xchange/open-xchange.log.0 <== ... (omitted logs) 2025-09-02T11:34:45,736+0200 INFO [OXWorker-0000445] com.openexchange.tools.oxfolder.OXFolderAdminHelper.addUserToOXFolders(OXFolderAdminHelper.java:1735) User 5 successfully created in context 10 ... (omitted logs) 2025-09-02T11:34:45,747+0200 INFO [OXWorker-0000445] com.openexchange.admin.storage.mysqlStorage.OXUserMySQLStorage.create(OXUserMySQLStorage.java:1788) User 5 created! ... (omitted logs) ==> /var/log/univention/listener_modules/ox-connector.log <== 2025-09-02 11:34:45 INFO univention.ox.soap.backend_base.SoapUser: Created user 'test.ox-01' in context 10 (id=5). 2025-09-02 11:34:45 INFO Changing user 5 to profile premium ... (omitted logs) -
Add user
test.ox-01to groupTest-Gruppe-01(via UMC).- No changes were made in the logs, indicating the listener event was probably ignored as the group wasn’t a fully registered OX group yet.
LDAP Search (Group
Test-Gruppe-01):root@ucs5primary:~# univention-ldapsearch cn=Test-Gruppe-01 # extended LDIF # # LDAPv3 # base <dc=miro,dc=intranet> (default) with scope subtree # filter: cn=Test-Gruppe-01 # requesting: ALL # # Test-Gruppe-01, groups, miro.intranet dn: cn=Test-Gruppe-01,cn=groups,dc=miro,dc=intranet cn: Test-Gruppe-01 gidNumber: 5092 sambaGroupType: 2 univentionGroupType: -2147483646 description: OX-Test-Gruppe univentionObjectIdentifier: 371219d8-929a-45e0-91a9-da7b4e1e5ab1 isOxGroup: OK sambaSID: S-1-5-21-3450543618-4260802429-757627796-11185 objectClass: top objectClass: sambaGroupMapping objectClass: oxGroup objectClass: posixGroup objectClass: univentionObject objectClass: univentionGroup univentionObjectType: groups/group uniqueMember: uid=test.ox-01,cn=users,dc=miro,dc=intranet memberUid: test.ox-01 -
Create a new group called
Test-Gruppe-02via UMC and add two users (test.ox-01andtest.ox-02) directly upon creation, as described in the documentation:
https://docs.software-univention.de/ox-connector-app/latest/usage.html#groupsListener Logs (Group
Test-Gruppe-02Creation):02.09.25 12:43:25.894 LDAP ( PROCESS ) : connecting to ldap://ucs5primary.miro.intranet:7389 02.09.25 12:43:25.914 LISTENER ( PROCESS ) : updating 'cn=Test-Gruppe-02,cn=groups,dc=miro,dc=intranet' command a ... (omitted logs) ==> /var/log/univention/listener_modules/ox-connector.log <== 2025-09-02 12:43:25 INFO create of cn=Test-Gruppe-02,cn=groups,dc=miro,dc=intranet (id: b'66406544-1c35-1040-8387-877d70335bf4', file: /var/lib/univention-appcenter/listener//ox-connector/2025-09-02-12-43-25-930144.json) ... (omitted logs) 2025-09-02 12:43:29 INFO Group Test-Gruppe-02 will be OX Group ... 2025-09-02 12:43:29 INFO Creating Object('groups/group', 'cn=Test-Gruppe-02,cn=groups,dc=miro,dc=intranet') ==> /var/log/open-xchange/open-xchange.log.0 <== ... (omitted logs) 2025-09-02T12:43:29,992+0200 ERROR [OXWorker-0000539] com.openexchange.admin.rmi.impl.OXCommonImpl.logAndReturnException(OXCommonImpl.java:336) com.openexchange.database.schema=localhost_5 ... com.openexchange.admin.rmi.exceptions.NoSuchGroupException: com.openexchange.admin.rmi.exceptions.NoSuchObjectException: com.openexchange.admin.rmi.exceptions.NoSuchGroupException: No such group Test-Gruppe-02 in context 10; exceptionId -989672406-14; exceptionId -989672406-16; exceptionId -989672406-18 at com.openexchange.admin.rmi.impl.OXGroup.getData(OXGroup.java:568) ... Caused by: com.openexchange.admin.rmi.exceptions.NoSuchGroupException: No such group Test-Gruppe-02 in context 10; exceptionId -989672406-14 at com.openexchange.admin.storage.mysqlStorage.OXToolMySQLStorage.getGroupIDByGroupname(OXToolMySQLStorage.java:1263) ... ==> /var/log/univention/listener_modules/ox-connector.log <== 2025-09-02 12:43:30 INFO Retrieving members... 2025-09-02 12:43:30 INFO Loading old object from /var/lib/univention-appcenter/apps/ox-connector/data/listener/old/ca15f39a-1c2b-1040-8372-877d70335bf4.json 2025-09-02 12:43:30 INFO ... found 5 2025-09-02 12:43:30 INFO Loading old object from /var/lib/univention-appcenter/apps/ox-connector/data/listener/old/f504c440-1c31-1040-837e-877d70335bf4.json 2025-09-02 12:43:30 INFO ... found 7 ==> /var/log/open-xchange/open-xchange.log.0 <== 2025-09-02T12:43:30,095+0200 INFO [OXWorker-0000539] com.openexchange.admin.storage.mysqlStorage.OXGroupMySQLStorage.create(OXGroupMySQLStorage.java:350) Group 8 created! ... ==> /var/log/univention/listener_modules/ox-connector.log <== 2025-09-02 12:43:30 INFO univention.ox.soap.backend_base.SoapGroup: Created group 'Test-Gruppe-02' in context 10 (id=8). ... (omitted logs)
The logs show that even a freshly created group (Test-Gruppe-02) with the required isOxGroup=OK attribute, even if configured as per documentation to include users, throws a NoSuchGroupException during the group synchronization process before ultimately being created in the Open-Xchange database (Group 8 created!). Despite being created in the database, the group is still not selectable in the OX frontend because it lacks the required mail address.
It should be ensured that groups have a mail address configured so that they are visible in the Open-Xchange frontend.
The groups themselves are synced to the Open-Xchange database by the OX-Connector even without a mail address as demonstrated by the final logs:
2025-09-02 17:14:23 INFO univention.ox.soap.backend_base.SoapGroup: Created group 'Test-OX-Group03' in context 10 (id=9).
2025-09-02 17:14:23 INFO mv /var/lib/univention-appcenter/apps/ox-connector/data/listener/2025-09-02-17-14-21-836535.json -> /var/lib/univention-appcenter/apps/ox-connector/data/listener/old/576b7c28-1c5a-1040-9b7d-3981634d120f.json
2025-09-02 17:14:23 INFO ... not done yet; enriching object by rewriting JSON file...
2025-09-02 17:14:23 INFO Successfully processed 1 files during this run
2025-09-02 17:14:23 INFO Successfully processed 0 files during this run
2025-09-02 17:14:23 INFO Success! Removing consumed files
Updating default
Portal data updated in 0.01s
Updating umc
root@ucs5primary:~# /opt/open-xchange/sbin/listgroup -c 10 -A oxadmin -P $(< /etc/ox-secrets/context10.secret)
Id Name Displayname Members
1 users Standard group 2,3,4,5
7 Test-OX-Group01 Test-OX-Group01 4,5
8 Test-OX-Group02 Test-OX-Group02 4,5
9 Test-OX-Group03 Test-OX-Group03 4,5
