If you have failures with your ox-connector and found the similar traceback in the following log file.
/var/log/univention/listener_modules/ox-connector.log
2024-01-14 00:00:32 INFO Started up with ox-connector=2.2.7
2024-01-14 00:00:32 INFO Using App account connection
2024-01-14 00:00:32 ERROR Fatal error:
File "/usr/share/univention-appcenter-listener-converter", line 211, in main
find_and_convert_files(app)
File "/usr/share/univention-appcenter-listener-converter", line 160, in find_and_convert_files
lo, pos = get_app_connection(app)
File "/usr/share/univention-appcenter-listener-converter", line 72, in get_app_connection
return get_read_connection(machine_account, machine_password)
File "/usr/lib/python3/dist-packages/univention/appcenter/udm.py", line 165, in get_read_connection
lo = base_access(host=host, port=port, base=base, binddn=userdn, bindpw=password)
File "/usr/lib/python3/dist-packages/univention/uldap.py", line 292, in __init__
self.__open(ca_certfile)
File "/usr/lib/python3/dist-packages/univention/uldap.py", line 371, in __open
self.bind(self.binddn, self.bindpw)
File "/usr/lib/python3/dist-packages/univention/uldap.py", line 212, in _decorated
return func(self, *args, **kwargs)
File "/usr/lib/python3/dist-packages/univention/uldap.py", line 306, in bind
self.lo.simple_bind_s(self.binddn, self.bindpw)
File "/usr/lib/python3/dist-packages/ldap/ldapobject.py", line 1215, in simple_bind_s
res = self._apply_method_s(SimpleLDAPObject.simple_bind_s,*args,**kwargs)
File "/usr/lib/python3/dist-packages/ldap/ldapobject.py", line 1197, in _apply_method_s
return func(self,*args,**kwargs)
File "/usr/lib/python3/dist-packages/ldap/ldapobject.py", line 444, in simple_bind_s
File "/usr/lib/python3/dist-packages/ldap/ldapobject.py", line 749, in result3
File "/usr/lib/python3/dist-packages/ldap/ldapobject.py", line 756, in result4
File "/usr/lib/python3/dist-packages/ldap/ldapobject.py", line 329, in _ldap_call
reraise(exc_type, exc_value, exc_traceback)
File "/usr/lib/python3/dist-packages/ldap/compat.py", line 44, in reraise
raise exc_value
File "/usr/lib/python3/dist-packages/ldap/ldapobject.py", line 313, in _ldap_call
result = func(*args,**kwargs)
ldap.INVALID_CREDENTIALS: {'desc': 'Invalid credentials'}
Hint:
The univention-appcenter-listener-converter connects to LDAP using the credentials of the memberserver account of the App. The username is in UCR,
ucr get appcenter/apps/ox-connector/hostdn
Output looks like:
cn=ox-co-85276525,cn=memberserver,cn=computers,dc=univention,dc=intranet
The password for the memberserver-account you will find in:
less /var/lib/univention-appcenter/apps/ox-connector/machine.secret
c9a49715f35b44f0dfa6199f1b6f47b1fad7d3a534996677de30d5975521dfeb
In our case it seems like the password was changed at first, which shouldn’t happen. UCS does not do this on its own!
or
The memberserver-account was missing/deleted.
Investigation:
Try to make an univention-ldapsearch with the memberserver-account to test the credentials:
univention-ldapsearch -D cn=ox-co-85276525,cn=memberserver,cn=computers,dc=univention,dc=intranet -W -s base
Enter LDAP Password: c9a49715f35b44f0dfa6199f1b6f47b1fad7d3a534996677de30d5975521dfeb
ldap_bind: Invalid credentials (49)
Check if the memberserver-account for the app exist with:
udm computers/memberserver list | grep DN
If the memberserver is not listed you should recreate it :
udm computers/memberserver create --position cn=memberserver,cn=computers,dc=univention,dc=intranet --set name=ox-co-85276525 --set password=c9a49715f35b44f0dfa6199f1b6f47b1fad7d3a534996677de30d5975521dfeb
Now the object was created and you could list with:
DN: cn=ox-co-85276525,cn=memberserver,cn=computers,dc=univention,dc=intranet
