Problem: OX-Connector can not process json with more than 100000 users
The ox-connector can not process a json file, and shows this message in logfile /var/log/univention/listener_modules/ox-connector.log
2023-06-08 07:31:23 WARNING During handling of the above exception, another exception occurred:
2023-06-08 07:31:23 WARNING Traceback (most recent call last):
2023-06-08 07:31:23 WARNING   File "/tmp/univention-ox-connector.listener_trigger", line 324, in run_on_files
2023-06-08 07:31:23 WARNING     f(obj)
2023-06-08 07:31:23 WARNING   File "/usr/lib/python3.9/site-packages/univention/ox/provisioning/__init__.py", line 108, in run
2023-06-08 07:31:23 WARNING     modify_group(new_obj)
2023-06-08 07:31:23 WARNING   File "/usr/lib/python3.9/site-packages/univention/ox/provisioning/groups.py", line 136, in modify_group
2023-06-08 07:31:23 WARNING     group.modify()
2023-06-08 07:31:23 WARNING   File "/usr/lib/python3.9/site-packages/univention/ox/soap/backend.py", line 180, in modify
2023-06-08 07:31:23 WARNING     self.service(self.context_id).change(obj)
2023-06-08 07:31:23 WARNING   File "/usr/lib/python3.9/site-packages/univention/ox/soap/services.py", line 431, in change
2023-06-08 07:31:23 WARNING     return self._call_ox('change', grp=grp)
2023-06-08 07:31:23 WARNING   File "/usr/lib/python3.9/site-packages/univention/ox/soap/services.py", line 163, in _call_ox
2023-06-08 07:31:23 WARNING     return getattr(service, func)(**kwargs)
2023-06-08 07:31:23 WARNING   File "/usr/lib/python3.9/site-packages/zeep/proxy.py", line 46, in __call__
2023-06-08 07:31:23 WARNING     return self._proxy._binding.send(
2023-06-08 07:31:23 WARNING   File "/usr/lib/python3.9/site-packages/zeep/wsdl/bindings/soap.py", line 135, in send
2023-06-08 07:31:23 WARNING     return self.process_reply(client, operation_obj, response)
2023-06-08 07:31:23 WARNING   File "/usr/lib/python3.9/site-packages/zeep/wsdl/bindings/soap.py", line 206, in process_reply
2023-06-08 07:31:23 WARNING     raise TransportError(
2023-06-08 07:31:23 WARNING zeep.exceptions.TransportError: Server returned response (413) with invalid XML: Invalid XML content received (Space required after the Public Identifier, line 1, column 50).
2023-06-08 07:31:23 WARNING Content: b'<!DOCTYPE HTML PUBLIC "-//IETF//DTD HTML 2.0//EN">\n<html><head>\n<title>413 Request Entity Too Large</title>\n</head><body>\n<h1>Request Entity Too Large</h1>\nThe requested resource<br />/webservices/OXGroupService<br />\ndoes not allow request data with POST requests, or the amount of data provided in\nthe request exceeds the capacity limit.\n</body></html>\n'
2023-06-08 07:31:23 INFO    This is consecutive error #162
Investigation:
The message means, that the requested resource /webservices/OXGroupService does not allow request data with POST requests, or the amount of data provided in the request exceeds the capacity limit.
The external OX Server has to be adjusted, to increase threshold for content length.
