with the login of the Opsiconfd client to the Opsimaster.
When you try to login via Client you get an “unauthorized”
The auth.log shows:
Oct 28 14:35:32 opsimaster opsiconfd: pam_krb5(opsi-auth:auth): (user username) attempting authentication as username@SCHEIN.ME
Oct 28 14:35:32 opsimaster opsiconfd: pam_krb5(opsi-auth:auth): (user username) krb5_get_init_creds_password: unable to reach any KDC in realm SCHEIN.ME
Oct 28 14:35:32 opsimaster opsiconfd: pam_krb5(opsi-auth:auth): authentication failure; logname=username uid=2011 euid=2011 tty= ruser= rhost=
Oct 28 14:35:32 opsimaster opsiconfd: pam_krb5(opsi-auth:auth): pam_sm_authenticate: exit (failure)
So the cannot reach the primary.
Investigation:
You can do some tauthentication tests
opsiconfd -l8 test pam_auth
Testing PAM authentication
Enter username: cscheini
Enter password: *********
→ see the result.
opsiconfd -l5 test ldap_auth
Testing LDAP authentication
- LDAP URL
Examples:
Active Directory / Samba 4
ldaps: //ad.company.de/dc=company,dc=de
OpenLDAP
ldap: //dap.company.de: 7389/dc=company, dc=de
ldaps: //10.10.1.2/dc=org, dc=tld
Enter LDAP URL: ldap: // master.schein.me: 7389/dc=schein,dc=me:
- Bind user (template)
{base) will be replaced with the base DN from the LDAP URL.
{username} will be replaced with the username to authenticate.
Examples:
{username)@company.de
OpenLDAP
uid={username},ou=Users,dc=org, dc=tld
uid={username},cn=Users,{base}
Enter bind user template: uid=(username}, cn=Users, (base}
- Group filter (optional)
The filter which is used when searching groups.
Examples:
(objectclass=group)
Enter group filter (optional): (&(objectClass=univentionGroup)(cn=opsiadmin))
Use memberof RDN?
If active, the RDN of the memberof attribute will be used
to get the group name, without searching the group.
Use memberOf RDN? [y/n] (n): n
Enter password:
- Install a new Memberserver as opsimasteror
or
- switch to openLdap authentication
This can be done, with the “tool” introduced in the investigation part.
opsiconfd test ldap_auth
If the test is successfull, you will be asked, to save the configuration directly, so it is usefull, to save the opsi configuration before (/etc/opsi/opsi.conf)
