When attempting to update UCS and the Open-Xchange (OX) App, the process fails because the OX App is not available for newer UCS releases. This prevents both UCS and Open-Xchange from being upgraded successfully.
Root Cause
A check using
ucr search --brief repository ox
revealed that the oxseforucs app is not properly registered in the App Center. Several expected entries are missing, such as:
appcenter/apps/oxseforucs/status
appcenter/apps/oxseforucs/ucs
appcenter/apps/oxseforucs/version
ucs/web/overview/entries/service/oxseforucs/*
Without these entries, the system cannot correctly identify or manage the OX App, which blocks further updates.
To resolve this issue, you can try reinstalling or re-registering the oxseforucs app.
First, create a snapshot of your system. This ensures you can roll back if anything goes wrong.
Attempt to reinstall the app using:
univention-app install oxseforucs-
If the system reports that the app is already installed, try to force the registration with:
univention-app register --do-it oxseforucs -
If you want to register a specific version of an app, you can list the available versions of the app and then use the version number for the registration:
univention-app list oxseforucs oxseforucs Name: OX App Suite Versions: 7.10.6-ucs11univention-app register --do-it oxseforucs=7.10.6-ucs11
After reinstallation or re-registration, verify that the missing
ucrentries now exist and retry the UCS and OX updates.
