After upgrading to UCS 5.2, the NTP server cannot be queried on either Domain Controller (DC) using ntpq -p.
When attempting to use ntpdate, the command fails with the following error:
***Request timed out
Root Cause
The issue is caused by missing localhost restriction entries in /etc/ntpsec/ntp.conf:
restrict 127.0.0.1
restrict ::1
With UCS 5.2, the standard NTP daemon was replaced by ntpsec. By default, ntpsec disables the ntpq control channel unless an explicit restriction policy is defined to permit localhost access.
Investigation
First, verify that the required packages are correctly installed on your system using the following command:
dpkg -l | grep ntp
The expected output should look like this:
ii ntp 1:4.2.8p15+dfsg-2~1.2.3-1 all Network Time Protocol daemon/utilities (transitional package)
rc ntpdate 1:4.2.8p15+dfsg-2~1.2.3-1 all Network Time Protocol client (transitional package)
ii ntpsec 1.2.3-1 amd64 Network Time Protocol daemon and utility programs
ii ntpsec-ntpdate 1.2.3-1 amd64 client for setting system time from NTP servers
ii ntpsec-ntpdig 1.2.3-1 amd64 ntpdig SNTP client
ii python3-elementpath 2.5.3-1 all Providing XPath selectors for Python's XML data structures
ii python3-ntp 1.2.3-1 amd64 Python 3 NTP Helper Classes
Note: If the transitional
ntppackage is not installed (e.g., showing a status ofrcfor removed/configured), you can reinstall it by running:
univention-install ntp
Next, check the current status of the time synchronization services:
systemctl status ntp.service
systemctl status ntpd.service
Verify the contents of the configuration file at /etc/ntpsec/ntp.conf. Ensure that it contains the expected local restriction policies:
# univention-config-registry.
# Please edit the following file(s) instead:
# /etc/univention/templates/files/etc/ntpsec/ntp.conf
# /etc/ntpsec/ntp.conf, configuration for ntpd; see ntp.conf(5) for help
driftfile /var/lib/ntpsec/ntp.drift
leapfile /usr/share/zoneinfo/leap-seconds.list
# To enable Network Time Security support as a server, obtain a certificate
# (e.g. with Let's Encrypt), configure the paths below, and uncomment:
# nts cert CERT_FILE
# nts key KEY_FILE
# nts enable
# You must create /var/log/ntpsec (owned by ntpsec:ntpsec) to enable logging.
statsdir /var/log/ntpsec
statistics loopstats peerstats clockstats
filegen loopstats file loopstats type day enable
filegen peerstats file peerstats type day enable
filegen clockstats file clockstats type day enable
server 192.168.0.XXX burst
server univention.de burst
ntpsigndsocket /var/lib/samba/ntp_signd
restrict default mssntp noquery
restrict 127.0.0.1
restrict ::1
tinker panic 0
### Synchronize with local server, if no other
### could be reached
server 127.127.1.0
fudge 127.127.1.0 stratum 5
Reproducibility
The issue can be reproduced consistently by commenting out the localhost restriction lines and restarting the service:
<skip>
#restrict 127.0.0.1
#restrict ::1
tinker panic 0
<skip>
Running the query command afterwards will trigger the timeout:
root@ucs5primary:~# ntpq -p
To resolve the issue, perform a UCR commit to regenerate the configuration file from the official Univention templates. This ensures the correct configuration block is written permanently.
- Regenerate the configuration file:
ucr commit /etc/ntpsec/ntp.conf
- Verify that the configuration now includes the required parameters:
<skip>
restrict 127.0.0.1
restrict ::1
<skip>
- Restart the NTP services to apply the changes:
systemctl restart ntp.service ntpsec.service
- Verify the NTP server status:
ntpq -p
- Expected Output:
remote refid st t when poll reach delay offset jitter
192.168.0.XXX 79.133.44.XXX 2 u 1 64 1 0.4129 0.2603 0.0000
10.208.1.XXX 130.162.220.XXX 2 u - 64 1 15.5582 3.6463 0.0000
univention.de .DNS. 16 u - 64 0 0.0000 0.0000 0.0002
LOCAL(0) .LOCL. 5 l - 64 0 0.0000 0.0000 0.0002
