Users are encountering a “Not Found” error when attempting to access their calendars via external applications. For instance, accessing a calendar through the URL https://ox.my.school/caldav/urkv392c93a results in a 404 error. Attempts to connect using clients like Thunderbird and Outlook also report that the calendar cannot be found.
Investigation
Check the User Agent in Apache Access Logs:
- Access the Apache access logs located at
/var/log/apache2/access.log. - Identify the User Agent string associated with the calendar access attempts by searching for the specific URL or related entries.
Verify User Agent in Apache Rewrite Rules:
- Examine the Apache configuration file, typically found at
/etc/apache2/sites-enabled/ox.conf. - Search for existing RewriteRules that may affect the identified User Agent:
grep Rewrite /etc/apache2/sites-enabled/ox.conf - Determine if the User Agent from the access logs is accounted for in these rules.
Update Apache Rewrite Rules:
- If the User Agent identified during the investigation is not present in the existing RewriteRules, consider adding it to ensure proper handling of calendar access requests:
ucr set ox/caldav/useragent/whitelist="$(ucr get ox/caldav/useragent/whitelist)|MyNewUserAgent" - Replace
MyNewUserAgentwith your desired User Agent that you identified. - Be aware that identifying email clients based on header information can vary and is not always reliable. Some clients use headers like
X-Maileror other fields for identification.
Reference User Agent Information:
- Utilize resources to better understand and identify User Agents:
Test the Configuration:
- After updating the RewriteRules, restart the Apache server to apply changes:
sudo systemctl restart apache2 - Test calendar access using the external applications to confirm that the “Not Found” error is resolved.
