Nextcloud environments are vulnerable to security risks associated with CVE-2026-109618 & CVE-2026-109619. Issues are detailed in GitHub #1693. This vulnerability stems from an underlying PHP issue that can affect server behavior and security when running impacted Nextcloud container/server images.
Root Cause
The issue is caused by a missing PHP fix in older Nextcloud application releases packaged for Univention Corporate Server (UCS) 5.2.
The following Nextcloud versions under UCS 5.2 are affected by this issue:
30.0.15-031.0.9-032.0.3-032.0.6-032.0.12-032.0.13-0
An update for Nextcloud implementing the necessary PHP fix is now available in the Univention App Center.
The fixed version 33.0.10-0 (5.2/nextcloud=33.0.10-0) has been officially released for UCS 5.2.
Verification and Upgrade Steps
Update the appcenter repository and verify available App Versions:
Run the following command to check the list of available versions for Nextcloud:univention-app update univention-app list nextcloudOutput:
nextcloud Name: Nextcloud Hub Versions: 33.0.10-0 30.0.15-0 31.0.9-0 32.0.3-0 32.0.6-0 32.0.12-0 32.0.13-0 -
Upgrade Nextcloud:
Upgrade to the latest Nextcloud application by executing:univention-app upgrade nextcloud
