In Nextcloud you get an error like this and accessing Samba shares within Nextcloud does not work.
"Es ist ein Fehler mit folgender Meldung aufgetreten:Icewind\SMB\Exception\DependencyException: No valid backend available, ensure smbclient is in the path or php-smbclient is installed. Do you want to review mount point config in admin settings page?"
Environment
Nextcloud app version: 19.0.3-0
Nextloud realized the smbclient offers poor performance and decided to switch to PHP smbclient. But enabling this in PHP was missed.
This is a known issue on Nextcloud and will be addressed. As a workaround enable the PHP package manually or install smbclient.
Option 1 (recommended)
univention-app shell nextcloud
echo 'extension=smbclient.so' >> /etc/php/7.4/apache2/conf.d/60-nextcloud.ini
echo 'extension=smbclient.so' >> /etc/php/7.4/cli/conf.d/60-nextcloud.ini
exit
univention-app restart nextcloud
Option 2
univention-app shell nextcloud apt install smbclient
Option 3
apt upgrade
apt install smbclient libsmbclient-dev
