After you created successfully a network, the netmask is not editable on the UMC.
Maybe that will be necessary because, something wrong happen or you want to be change the network structure.
The Bug 55868 for that issue.
For a workaround you can use ldapmodify to change the netmaks with an modified ldif.
At first you have to list your network you want to edit with:
udm networks/network list --filter cn=networkname*
Then create an ldif with the output from:
univention-ldapsearch cn=networkname -xLLL > networkname-mask.ldif
Now use an editor you like, and modify the created ldif file with the netmask you need, for example like this:
DN: cn=networkname,cn=networks,dc=ucs5test,dc=intranet
changetype: modify
replace: univentionNetmask
univentionNetmask: 20
With the modified ldif, you have to use ldapmodify and your ldif file like following command:
ldapmodify -x -D cn=admin,$(ucr get ldap/base) -y /etc/ldap.secret -f networkname-mask.ldif
At least, check the network again an the new modified netmask
DN: cn=default,cn=networkname,dc=ucs5test,dc=intranet
dhcpEntryZone: None
dnsEntryZoneForward: zoneName=ucs5test.intranet,cn=dns,dc=ucs5test,dc=intranet
dnsEntryZoneReverse: zoneName=30.200.10.in-addr.arpa,cn=dns,dc=ucs5test,dc=intranet
netmask: 20
network: 10.200.30.0
nextIp: 10.200.30.1
