Nach dem Installieren kann das Import Modul nicht aufgerufen werden.
Es kommt folgender Fehler:
20.07.21 11:39:13.416 MAIN ( ERROR ) : Internal server error during "schoolimport/schools".
Request: schoolimport/schools
File "/usr/lib/python2.7/dist-packages/univention/management/console/base.py", line 359, in __error_handling
six.reraise(etype, exc, etraceback)
File "/usr/lib/python2.7/dist-packages/univention/management/console/base.py", line 262, in execute
function.__func__(self, request, *args, **kwargs)
File "/usr/lib/python2.7/dist-packages/univention/management/console/modules/decorators.py", line 641, in _decorated
return function(self, request, *args, **kwargs)
File "/usr/lib/python2.7/dist-packages/univention/management/console/modules/decorators.py", line 321, in _response
result = _multi_response(self, request)
File "/usr/lib/python2.7/dist-packages/univention/management/console/modules/decorators.py", line 181, in _response
return function(self, request)
File "/usr/lib/python2.7/dist-packages/univention/management/console/modules/decorators.py", line 443, in _response
return list(function(self, iterator, *nones))
File "/usr/lib/python2.7/dist-packages/univention/management/console/modules/decorators.py", line 289, in _fake_func
yield function(self, *args)
File "/usr/lib/python2.7/dist-packages/univention/management/console/modules/schoolimport/__init__.py", line 104, in schools
dict(id=school.name, label=school.displayName) for school in self.client.school.list()
File "/usr/lib/python2.7/dist-packages/ucsschool/http_api/client.py", line 593, in list
return self._to_python(self._list_resource(**params))
File "/usr/lib/python2.7/dist-packages/ucsschool/http_api/client.py", line 551, in _list_resource
return self._resource_from_url(resource_url, **params)
File "/usr/lib/python2.7/dist-packages/ucsschool/http_api/client.py", line 543, in _resource_from_url
return self.client.call_api("get", url, params=params)
File "/usr/lib/python2.7/dist-packages/ucsschool/http_api/client.py", line 524, in call_api
raise exc(msg, status_code=response.status_code)
ServerError: Received status_code=500 with reason='Internal Server Error' for requests.get(**files=None, url=u'https://school.schein.en/api/v1/schools/', auth=(u'Administrator', u'**********'), headers={u'Accept': u'application/json'}, params={}, data=None).
Das Problem wurde mit ucs-school-import 17.0.70A~4.4.0.202106291122 eingeführt und mit ucs-school-import 7.0.71A~4.4.0.202107141220 behoben.
Trotzdem verschwindet der Traceback nicht.
Nachdem die letzen Erratas eingespielt wurden, muss das Joinskript 40ucs-school-import-http-api.inst nochmal ausgeführt werden. Danach müssen die Dienste, idealerweise der Server, einmal rebootet werden.
univention-run-join-scripts --run-scripts 40ucs-school-import-http-api.inst --force
systemctl restart ucs-school-import-celery-worker.service
systemctl restart celeryd.service
systemctl restart ucs-school-import-http-api.service
systemctl restart rabbitmq-server.service
