Problem: Member Server Causes High Load on LDAP Master
Based on this article you identified the server causing a high CPU load on the master.
Investigation
Check if ldap-group-to-file.py is running at least once.
Note: Starting with UCS 4.4 e191 it will run only once.
root@ucs:~# ps ax | grep ldap-group-to
14217 pts/0    S+     0:00 grep ldap-group-to
32435 ?        Ss     0:08 ldap-group-to-file.py
32123 ?        Ss     0:08 ldap-group-to-file.py
23456 ?        Ss     0:08 ldap-group-to-file.py
32450 ?        Ss     0:08 ldap-group-to-file.py
Improve runtime and start time of this script based on this article.
Mastodon
