Problem: Logrotate Emails About Errors During Compression
You are getting emails regarding an issue while compressing logfiles like the following:
> ---------- Ursprüngliche Nachricht ----------
> Von: root@ucs.multi.ucs
> An: root@ucs.multi.ucs
> Datum: 16. Dezember 2018 um 06:25
> Betreff: Cron <root@ucs> test -x /usr/sbin/anacron || ( cd / && run-parts
> --report /etc/cron.daily )
> /etc/cron.daily/logrotate:
> error: Compressing program wrote following message to stderr when compressing log
> /var/log/univention/listener.log.1:
> gzip: stdin: file size changed while zipping
Root Cause
The univention-directory-listener might hang (at least partially) and thus does not react to the default “term” signal. So the process continues to write to the rotated logfile resulting in an error from gzip.
Send the “kill” Signal to the process to force the termination:
killall -9 /usr/sbin/univention-directory-listener
The service should restart automatically.
