log.smbd repeatedly show this message:
[2022/12/19 01:02:03.123456, 0] ../../source3/auth/auth.c:441(load_auth_module)
load_auth_module: can't find auth method guest!
Check if the samba parameter “auth methods” has been explicitly configured
testparm -s --parameter-name="auth methods" 2>/dev/null
e.g. via this UCR variable:
ucr search "samba/global/options/auth methods"
If it shows the value guest then replace it by anonymous, e.g. by running
ucr set samba/global/options/"auth methods"="$(ucr get samba/global/options/"auth methods" | sed s/guest/anonymous/)"
And then reload the samba configuration by running
smbcontrol all reload-config
This is a per host solution and needs to be checked/repeated on each system running samba, where the samba parameter “auth methods” has been explicitly configured. If this has been done via UCR policy, the policy should be checked and adjusted accordingly.
