The lockingdb.sqlite file is high above GB in size
-rw-r--r-- 1 root root 13G Dez 12 08:09 /etc/univention/connector/lockingdb.sqlite
Investigation
Check the rejected status of the connector. If you find rejects here, try to solve them with the help of this article:
S4-Connector:
univention-s4connector-list-rejected
AD-Connector:
univention-connector-list-rejected
If all rejects are resolved, both tables can be emptied in the database.
Of course you are welcome to make a backup. Before you do so, stop the S4 connector, empty tables using sqlite3 and restart the connector.
/etc/init.d/univention-s4-connector stop
sqlite3 /etc/univention/connector/lockingdb.sqlite
sqlite>.tables # show tables
sqlite> select * from UCS_LOCK; # have a look, if you want
sqlite> select * from S4_LOCK;
sqlite> DELETE from UCS_LOCK; # empty
sqlite> DELETE from S4_LOCK;
sqlite> VACUUM;
sqlite>.quit
/etc/init.d/univention-s4-connector start
