You run a univention-ldapsearch and get the following message
ldap_bind: Invalid credentials (49)
Normally this article will help in most cases
Change password machine.secret
But in our case a udm command like udm users/users list also not work and get the same message
Because the password for the ldap.secret is wrong or missing, but this is necessary for the cn=admin Account to make the ldap useable.
Bug 47455
Log into a terminal on your DC-Master as root and use the following steps:
# Setup temporary password
. /usr/share/univention-lib/base.sh
tmp="$(mktemp)"
create_machine_password >"$tmp"
# Configure temporary password
printf 'dn: olcDatabase={1}mdb,cn=config\nchangetype: modify\nadd: olcRootPW\nolcRootPW: %s\n\n' "$(slappasswd -T "$tmp")" | ldapmodify -QY EXTERNAL -H ldapi:///
# Create and change to new password
create_machine_password >/etc/ldap.secret
ldappasswd -H ldapi:/// -D "cn=admin,$(ucr get ldap/base)" -y "$tmp" -T /etc/ldap.secret
# Undo temporary password
printf 'dn: olcDatabase={1}mdb,cn=config\nchangetype: modify\ndelete: olcRootPW\n\n' | ldapmodify -QY EXTERNAL -H ldapi:///
# Remove the temporary password
rm -f "$tmp"
# You can get the crypted password showable if you want with
slapcat -a '(cn=admin)' -o ldif-wrap=no | sed -ne 's/^userPassword:: //p;T;q' | base64 -d
# Test if it works now
udm users/user list --filter uid=Administrator | grep DN:
and
univention-ldapsearch uid=Administrator dn
So if the udm command works, the ldap.secret password are correctly created.
Just if the univentiona-ldapsearch fails, it will be possible you have to use this article as next
