You cannot login via UMC, you get the following error message.
The SAML response contained a invalid signature: Failed to verify signature
"Could not fulfill the request. Server error message: The SAML response contained a invalid signature: Failed to verify signature"
The SAML certificates between Keycloak (Identity Provider) and UCS (Service Provider) do not match. This commonly occurs after:
- Keycloak updates
- Certificate renewals
- Changes to the Keycloak configuration
Step 1: Verify the Problem
Compare both certificates to confirm the cause help.univention.com:
# Retrieve certificate from Keycloak
curl https://ucs-sso-ng.YOUR-DOMAIN.com/realms/ucs/protocol/saml/descriptor
# Check locally stored certificate
cat /usr/share/univention-management-console/saml/idp/ucs-sso-ng.YOUR-DOMAIN.com.xml
Note: Replace YOUR-DOMAIN.com with your actual domain.
The certificates should be identical. If they differ, proceed to Step 2.
Step 2: Check Current Configuration
ucr get umc/saml/idp-server
The output should look something like:
Step 3: Re-synchronize Certificate
Even if the UCR variable is already set correctly, it needs to be reset to reload the certificate help.univention.com:
ucr set umc/saml/idp-server='https://ucs-sso-ng.YOUR-DOMAIN.com/realms/ucs/protocol/saml/descriptor'
What happens:
- The file
/usr/share/univention-management-console/saml/idp/ucs-sso-ng.YOUR-DOMAIN.com.xmlis recreated - The current certificate is downloaded from Keycloak
- The SAML configuration is updated
You should see output like this:
Setting umc/saml/idp-server
Module: setup_saml_sp
Try to download idp metadata (1/60)
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
100 3444 100 3444 0 0 273k 0 --:--:-- --:--:-- --:--:-- 280k
Multifile: /etc/pam.d/univention-management-console
File: /etc/ldap/sasl2/slapd.conf
Step 4: Test Login
Try logging in via UMC again. The error should be resolved.
Note for Environments Without Keycloak
If you’re using SimpleSAMLphp instead of Keycloak, the solution is different.
