Problem: Keycloak LOGIN_ERROR: username_in_use and invalid_user_credentials in Distributed LDAP Deployments
Users were unable to authenticate against an OpenDesk environment integrated with Keycloak.
The issue manifested as login failures in the authentication flow and inconsistent user resolution between LDAP replicas.
The following errors were visible in the Keycloak logs:
2026-02-11 11:53:00,271 WARN [org.keycloak.events] (executor-thread-1940) type="LOGIN_ERROR", realmId="opendesk", realmName="opendesk", clientId="https:///univention/oidc/", userId="f::name.surname", ipAddress="", error="invalid_user_credentials", auth_method="openid-connect", auth_type="code", redirect_uri="https:///univention/oidc/", code_id="", username="name.surname"
2026-02-11 11:51:59,458 WARN [org.keycloak.events] (executor-thread-8378) type="LOGIN_ERROR", realmId="opendesk", realmName="opendesk", clientId="https:///univention/oidc/", userId="null", ipAddress="", error="username_in_use", auth_method="openid-connect", auth_type="code", redirect_uri="https:///univention/oidc/", code_id="", username="name.surname"
Further investigation revealed inconsistent LDAP data between primary and secondary LDAP nodes. Multiple LDAP objects with the same uid but different entryUUID values existed on some LDAP secondaries.
The issue affected significantly more than a single account. Approximately 150 user objects showed inconsistent replication states across LDAP replicas.
Root Cause
The root cause was an inconsistent LDAP replication state between LDAP primary and secondary nodes.
Two major inconsistency patterns were identified:
  1. Duplicate LDAP objects with identical uid values but different entryUUID values existed on some secondary LDAP nodes.
  2. Secondary LDAP nodes contained newer password-related attributes and timestamps than the LDAP primaries.
This resulted in different LDAP replicas returning different user objects during authentication requests.
Because Keycloak queried inconsistent LDAP backends, the authentication flow produced:
  • username_in_use
  • invalid_user_credentials
The inconsistent replication state likely originated from replication failures or synchronization corruption within the LDAP syncrepl process.
The recommended remediation approach was to rebuild the affected LDAP secondary replicas sequentially.
Important Notes Before Proceeding
Before recreating LDAP secondaries:
  • verify whether secondary nodes contain newer or unique data
  • compare password-related attributes
  • verify whether user objects exist exclusively on secondaries
  • review modifyTimestamp
  • review entryCSN
  • review pwdChangedTime
Because secondaries contained newer password-related information in some cases, the environment required careful validation before discarding replica data.
Recreate LDAP Secondary Pods Sequentially
Delete the PersistentVolumeClaim and then the affected LDAP secondary pod.
Example:
kubectl delete pvc -n ${NAMESPACE} shared-data-ums-ldap-server-secondary-0
kubectl delete pod -n ${NAMESPACE} ums-ldap-server-secondary-0
Repeat the procedure for the remaining LDAP secondary pods.
Important:
  • only recreate one secondary at a time
  • wait for complete synchronization before continuing with the next secondary
  • monitor synchronization progress carefully
Verify Synchronization Status
Synchronization status can be verified through:
  • syncrepl logs
  • contextCSN convergence
  • LDAP service availability
The LDAP secondary service can be monitored to verify whether rebuilt replicas become operational again.
Example:
kubectl -n $NAMESPACE get services | grep ldap
Verify LDAP Object Consistency
Compare LDAP objects across all LDAP nodes before and after synchronization.
Example command:
kubectl exec -n $NAMESPACE ums-ldap-server-primary-0 -- ldapsearch -LLL -x -D "$(kubectl get -n $NAMESPACE configmaps ums-ldap-server-primary -o json | jq -r '.data.ADMIN_DN')" -w "$(kubectl get -n $NAMESPACE secrets ums-ldap-server-admin -o json | jq -r '.data.password' | base64 -d)" -b "$(kubectl get -n $NAMESPACE configmaps ums-ldap-server-primary -o json | jq -r '.data.LDAP_BASEDN')" uid=<USER> '+' '*' | less
Run the command against:
  • all LDAP primaries
  • all LDAP secondaries
Compare:
  • entryUUID
  • modifyTimestamp
  • entryCSN
  • password-related attributes
  • object existence
  • membership attributes
Investigation
Initial LDAP Inconsistency Findings
Two LDAP objects with the same uid but different entryUUID values existed on some secondary nodes.
LDAP data from affected secondaries:
dn: uid=name.surname,ou=users,ou=00,ou=,ou=tenants,dc=
structuralObjectClass: inetOrgPerson
entryUUID: 1ed06760-54c8-1040-9e86-49b22db34325
creatorsName: uid=,cn=users,dc=
createTimestamp: 20251113103447Z
memberOf: cn=Default group,cn=groups,dc=
memberOf: cn=managed-by-attribute-Fileshare,cn=groups,dc=
memberOf: cn=managed-by-attribute-Knowledgemanagement,cn=groups,dc=
memberOf: cn=managed-by-attribute-Livecollaboration,cn=groups,dc=
memberOf: cn=managed-by-attribute-Videoconference,cn=groups,dc=
memberOf: cn=-users,ou=groups,ou=00,ou=,ou=tenants,dc=
memberOf: cn=Domain Users,cn=groups,dc=
pwdChangedTime: 20251128112219Z
entryCSN: 20251128112219.385099Z#000000#003#000000
modifyTimestamp: 20251128112219Z
modifiersName: cn=admin,dc=
entryDN: uid=name.surname,ou=users,ou=00,ou=,ou=tenants,dc=
subschemaSubentry: cn=Subschema
hasSubordinates: FALSE
dn: uid=name.surname,cn=users,dc=
entryUUID: 4213527a-55ac-1040-8892-079a62eba42b
createTimestamp: 20251114134751Z
entryCSN: 20251114134751.578035Z#000000#002#000000
modifyTimestamp: 20251114134751Z
entryDN: uid=name.surname,cn=users,dc=
LDAP data from primaries and one secondary:
pwdChangedTime: 20260211115046Z
entryCSN: 20260211115046.846997Z#000000#002#000000
modifyTimestamp: 20260211115046Z
Extended Replication Analysis
Additional investigation showed:
  • approximately 150 affected accounts
  • password-related attribute divergence
  • objects existing only on selected replicas
  • newer timestamps on secondaries
  • modified telephone numbers
  • additional jpegPhoto attributes
In many cases, only password-related attributes differed.
Example differences found only on affected secondaries:
userPassword:: [different value]
krb5Key:: [different value]
krb5KeyVersionNumber: 3
pwhistory: {BCRYPT}[different value] {BCRYPT}[different value]
sambaNTPassword: [different value]
shadowLastChange: 20426
sambaPwdLastSet: 1764832021
pwdChangedTime: 20251204070701Z
entryCSN: 20251204070701.070870Z#000000#003#000000
modifyTimestamp: 20251204070701Z
Additional attributes present only on some secondaries:
objectClass: univentionPasswordSelfService
univentionPasswordSelfServiceEmail:
univentionPasswordRecoveryEmailVerified: TRUE
Service Verification
LDAP services were verified using:
kubectl -n agora-oegd get services | grep ldap
Output:
ums-ldap-notifier                           ClusterIP          <none>            6669/TCP                                       38d
ums-ldap-server                             ClusterIP          <none>            389/TCP,636/TCP                                38d
ums-ldap-server-primary                     ClusterIP          <none>            389/TCP,636/TCP                                38d
ums-ldap-server-primary-0                   ClusterIP          <none>            389/TCP,636/TCP                                38d
ums-ldap-server-primary-1                   ClusterIP          <none>            389/TCP,636/TCP                                38d
ums-ldap-server-primary-notifier            ClusterIP          <none>            389/TCP,636/TCP                                38d
ums-ldap-server-secondary                   ClusterIP      None         <none>            389/TCP,636/TCP                                38d
Connectivity testing confirmed:
  • secondaries could connect to primaries
  • primaries could connect to secondaries
  • LDAP TCP connectivity was functional
Additional Operational Considerations
The readiness probes for LDAP secondaries only verified TCP socket availability.
As a result:
  • LDAP secondaries could become reachable before synchronization was fully complete
  • read requests routed to rebuilding secondaries could temporarily fail
  • round-robin traffic distribution increased the risk of intermittent authentication failures during replica rebuilds
Additional Notes
  • Password changes were suspected to originate from the user self-service portal or password recovery workflows.
  • Password-related inconsistencies strongly indicated replication divergence after user password updates.
  • The issue demonstrated that LDAP replicas can contain newer data than primaries in broken replication scenarios.
  • Careful validation is required before deleting replicas if secondaries contain potentially newer authentication data.
  • Sequential secondary rebuilds remain the safest remediation strategy in heavily diverged replication environments.
