Symptom 1:
Join gives an error or users can not login frequently.
User logon works for a while but fails suddenly. Different users are be affected but the users change. When trying to login through Windows they get “No Authentication Server available”.
Symptom 2:
The join of a system fails (likely in 98univention-samba4slavepdc-dns.inst
, but not only) with the following written in the file /var/log/univention/join.log
Failed to get Kerberos credentials, falling back to samba-tool: (3221225581, 'The attempted logon is invalid. This is either due to a bad username or authentication information.')
Investigation
Step 1
Check your DNS Settings.
Step 2
Verify your to-be-joined computer can resolve domain controller DNS entries:
root@master:~# host gc._msdcs.$(ucr get domainname) 127.0.0.1
Using domain server:
Address: 127.0.0.1#53
Aliases:
gc._msdcs.multi.ucs has address 10.250.200.101
gc._msdcs.multi.ucs has address 10.250.200.102
gc._msdcs.multi.ucs has address 10.250.200.100
Step 3
Check for legacy DNS zones.
root@ucs:~# univention-s4search CN=MicrosoftDNS --cross-ncs dn | grep -i "cn=system"
dn: DC=_msdcs,DC=multi.ucs,CN=MicrosoftDNS,CN=System,DC=multi,DC=ucs
There should NOT be a DC=_msdcs
object entry below the CN=MicrosoftDNS,CN=System
container.
Verify existence of additional zones by the DNS service in /var/log/daemon.log
Mar 12 13:26:20 slave named[18248]: samba_dlz: Ignoring duplicate zone 'multi.ucs' from 'DC=@,DC=multi.ucs,CN=MicrosoftDNS,DC=DomainDnsZones,DC=multi,DC=ucs'
Mar 12 13:26:20 slave named[18248]: samba_dlz: Ignoring dnsZone _msdcs.multi.ucs
Step 4
The S4 connector by default synchronizes DNS entries from OpenLDAP to up-to-date location in Microsoft DNS. Previously (in Windows 2000) the DNS zones have been at a different location. Verify the S4 connector does not use legacy zones:
ucr get connector/s4/mapping/dns/position
Conclusion
There exists a duplicate zone in the legacy tree of CN=MicrosoftDNS,CN=System
which gets loaded first by the named service. But as the S4 connector by default does not sync into the legacy tree this zone is very likely outdated.
Step 1
On the master (or @school-slave) migrate existing zone info to new location with the script migrate_legacy_dns_zones attached to
the Bug 43692 - Migrate Samba 4 DNS data from the legacy to the default partition. It is also essential that the unmodified script is used, please avoid Copy&Paste and rather use wget or similar methods.
Step 2
Now make sure the S4 connector does not sync to legacy branches:
ucr unset connector/s4/mapping/dns/position
systemctl restart univention-s4-connector
Step 3
If the issue still exists and you still find entries in your /var/log/daemon.log
regarding duplicate zone, start over with step 1.
Remove the duplicate entry:
ldbdel -H /var/lib/samba/private/sam.ldb DC=_msdcs,DC=multi.ucs,CN=MicrosoftDNS,CN=System,DC=multi,DC=ucs
systemctl restart bind9
Now the join should be possible again and users should not notice any issues during logins.
legacy, dns , CN=MicrosoftDNS,CN=System , connector/s4/mapping/dns/position, migrate_legacy_dns_zones
