During the join an error appears and the join.log shows:
Configure 43univention-virtual-machine-manager-node-common.inst Mon Nov 19 15:31:16 CET 2018
2018-11-19 15:31:16.976456415+01:00 (in joinscript_init)
Object exists: (nolock) The attribute 'gidNumber' could not get locked.
E: object not found
__JOINERR__:FAILED: /usr/lib/univention-install/43univention-virtual-machine-manager-node-common.inst
* Join failed! *
* Contact your system administrator *
* Message: Please visit https://help.univention.com/t/8842 for common problems during the join and how to fix them -- FAILED: 43univention-virtual-machine-manager-node-common.inst
The host to be joined was joined before. In order to properly re-join the host first all data of this host should be purged.
Step 1
Remove the locking first as describe in this article.
Step 2
Once done execute the script:
/usr/share/univention-samba4/scripts/purge_s4_computer.py --computername=<HOSTNAME>
Step 3
Finally, restart the join.
