Problem: IndexError: list index out of range
You find this Traceback
  File "/usr/share/univention-directory-manager-tools/univention-cli-server", line 219, in doit
    output = univention.admincli.admin.doit(arglist)
  File "/usr/lib/python2.7/dist-packages/univention/admincli/admin.py", line 409, in doit
    out = _doit(arglist)
  File "/usr/lib/python2.7/dist-packages/univention/admincli/admin.py", line 620, in _doit
    univention.admin.modules.init(lo, position, module)
  File "/usr/lib/python2.7/dist-packages/univention/admin/modules.py", line 201, in init
    update_extended_attributes(lo, module, position)
  File "/usr/lib/python2.7/dist-packages/univention/admin/modules.py", line 363, in update_extended_attributes
    object_class = attrs.get('univentionUDMPropertyObjectClass', [])[0]
Investigation:
This can happen when listing in udm
udm container/cn list
but you can also find this during join
In this case univentionUDMPropertyObjectClass is empty or not present. In most cases the custom attributes are corrupt or incorrect.
You can approach the root cause with ldapsearch:
univention-ldapsearch '(&(!(univentionUDMPropertyObjectClass=*))(univentionObjectType=settings/extended_attribute))' -b "cn=custom attributes,cn=univention,$(ucr get ldap/base)"
These Objects should be checked, the may cause the traceback.
Remove or repair the found objects.
