You are getting errors in UMC and/ or listener.log:
com.openexchange.admin.rmi.exceptions.InvalidDataException: Field "display_name" is a mandatory field and can't be set to null.
This is a known bug of the OX-App-Suite with versions earlier than 7.10.3-ucs3.
Step 1
Upgrade your app to 7.10.3-ucs3.
Step 2
Display the current users with the faulty attributes in the listener queue with /usr/share/univention-ox/manage_listener_queue --list:
Write them down!
root@ucs-ox:~# /usr/share/univention-ox/manage_listener_queue --list
Date | Module | * | Name | Timestamp
2020-05-14 11:09:07 | user | m | v2344 | 1589447347.9854829311
2020-05-19 13:51:01 | user | m | q8274 | 1589889061.6214749813
2020-05-19 13:51:25 | user | m | b0504 | 1589889085.6683609486
(*) The command (a/m/d/n) is only available for user and group objects.
Step 3
Remove the objects by
/usr/share/univention-ox/manage_listener_queue --delete
Step 4
Modify the above notes users in UMC by editing their descriptions. This will trigger a resync of the user object to OX and fix the attribute issue.
