Computers having been imported do not appear in the classroom module.
UCS has a migration script /usr/share/ucs-school-import/scripts/migrate_ucsschool_roleswhich makes sure the objects have the correct objectClass.
Use the tool according to it’s usage info:
root@master:/usr/share/ucs-school-import/scripts# ./migrate_ucsschool_roles -h
usage: migrate_ucsschool_roles [-h] [--modify] [--force] [--schools SCHOOLS]
[--all-objects] [--school-groups]
[--class-shares] [--work-group-shares]
[--computer-rooms] [--school-classes]
[--servers-central] [--servers-school]
[--computers-school] [--users] [--work-groups]
Set ucsschoolRole property on UCS@school objects (users, work groups, school
classes, computer rooms, class shares, school servers) and central server
objects.
optional arguments:
-h, --help show this help message and exit
--modify Enable writing of modifications to LDAP. If unset, the
default is to make a dry run.
--force Overwrite existing role data. If unset, the default is
to not modify objects that already have data in the
role attribute.
--schools SCHOOLS Comma separated list of OUs whose objects should be
modified. If unset all OUs will be modified.
--all-objects Modify all UCS@school objects.
--school-groups Modify UCS@school specific group objects.
--class-shares Modify UCS@school class share objects.
--work-group-shares Modify UCS@school work group share objects.
--computer-rooms Modify UCS@school computer room objects.
--school-classes Modify UCS@school school class objects.
--servers-central Modify central server objects (DC master, DC backup, DC
slave, memberserver).
--servers-school Modify UCS@school school server objects (DC slave admin
& edu, memberserver).
--computers-school Modify UCS@school school client computer objects (Win,
IP managed and Mac OS computers).
--users Modify UCS@school user objects.
--work-groups Modify UCS@school work group objects.
Logfile: /var/log/univention/ucsschool-roles-migration.log
