Problem: essential packages were deleted during update
During update the package status got corrupted. This might be caused by already removed packages before the update
The updater.log shows:
/var/log/univention/updater.log
2026-07-26T04:10:36.455560+02:00 INIT
**** Starting univention-updater 5.2-5 with parameter=[‘/usr/share/univention-updater/univention-updater’, ‘net’, ‘–updateto=5.0-999’, ‘–silent’, ‘–noninteractive’]
—>DBG:update_available(mode=net)
Checking network repository
Update hold at 5.2-5, next 5.2-6 is after 5.0-999
Starting univention-upgrade. Current UCS version is 5.2-5 errata538
Checking for package updates: found
Please rerun command without --check argument to install.
Checking for package updates: Traceback in univention-upgrade:
File “/usr/lib/python3/dist-packages/univention/updater/scripts/upgrade.py”, line 410, in do_update
update_available = performUpdate(options, checkForUpdates=options.check, silent=False)
File “/usr/lib/python3/dist-packages/univention/updater/scripts/upgrade.py”, line 113, in performUpdate
if func(options, checkForUpdates, silent):
File “/usr/lib/python3/dist-packages/univention/updater/scripts/upgrade.py”, line 169, in do_package_updates
new_packages, upgraded_packages, removed_packages = updater.component_update_get_packages()
File “/usr/lib/python3/dist-packages/univention/updater/tools.py”, line 1400, in component_update_get_packages
raise UnmetDependencyError(stderr)
univention.updater.errors.UnmetDependencyError: You have unmet dependencies E: Unmet dependencies. Try ‘apt --fix-broken install’ with no packages (or specify a solution).
Following the instruction will cause more damage, because more important package will be removed.
Paketlisten werden gelesen… Fertig
Abhängigkeitsbaum wird aufgebaut… Fertig
Statusinformationen werden eingelesen… Fertig
Die folgenden Pakete wurden automatisch installiert und werden nicht mehr benötigt:
  heimdal-kdc heimdal-servers libkdc2-heimdal memtest86+ nfs-kernel-server postgresql-client postgresql-client-11 postgresql-client-15 postgresql-client-9.4 postgresql-client-9.6
postgresql-client-common python3-filetype python3-gdbm python3-gnupg python3-mimeparse python3-pygresql python3-renderpm
  python3-reportlab python3-reportlab-accel python3-trml2pdf python3-univention-directory-manager-rest python3-univention-directory-manager-rest-client
python3-univention-directory-reports python3-univention-group-membership-cache python3-univention-pkgdb python3-univention-portal python3-wheel
  univention-container-role-common univention-container-role-server-common univention-directory-manager-rest univention-directory-notifier univention-directory-reports
univention-docker-container-mode univention-firewall univention-group-membership-cache univention-heimdal-kdc univention-initrd
  univention-ldap-acl-master univention-ldap-config-master univention-license-import univention-mail-postfix univention-maintenance univention-management-console-module-ipchange
univention-management-console-module-udm univention-management-console-module-welcome univention-nfs-server univention-pkgdb-tools
  univention-portal univention-role-common univention-server-overview univention-support-info univention-telemetry
Verwenden Sie »apt autoremove«, um sie zu entfernen.
0 aktualisiert, 0 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
Investigation:
/var/log/apt/history.log shows:
Start-Date: 2026-07-27 10:32:28
Commandline: apt --fix-broken install
Install: linux-image-6.1.0-51-amd64:amd64 (6.1.177-1, automatic)
Error: Sub-process /usr/bin/dpkg returned an error code (1)
End-Date: 2026-07-27 10:32:28
Start-Date: 2026-07-27 10:33:14
Install: univention-container-role-server-common:amd64 (17.5.1, automatic), univention-docker-container-mode:amd64 (7.4.0, automatic), univention-container-role-common:amd64 (17.5.1, automat
ic)
Remove: univention-bind:amd64 (16.4.0), linux-image-amd64:amd64 (6.1.177-1), univention-role-server-common:amd64 (17.5.1), univention-server-master:amd64 (17.5.1)
Purge: linux-image-6.1.0-49-amd64:amd64 (6.1.174-1), linux-image-5.10.0-0.deb10.37-amd64:amd64 (5.10.247-1~deb10u1), linux-image-6.1.0-48-amd64:amd64 (6.1.172-1), linux-image-6.1.0-45-amd64:
amd64 (6.1.170-1), linux-image-6.1.0-50-amd64:amd64 (6.1.176-1), linux-image-5.10-amd64:amd64 (5.10.247-1~deb10u1)
End-Date: 2026-07-27 10:33:43
Remove: univention-role-server-common:amd64 (17.5.1), univention-server-master:amd64 (17.5.1)
The univention-server-master package was uninstalled due to a dependency conflict between univention-role-server-common and univention-container-role-server-common. This was triggered by the apt --fix-broken install command. We have a bug report for this:
Bug 58827
Installing the removed packages again, the server/role comes back:
univention-install univention-bind linux-image-amd64 univention-role-server-common univention-server-master linux-image-6.1.0-49-amd64 linux-image-6.1.0-50-amd64 linux-image-6.1.0-51-amd64
OK:2 https://updates.software-univention.de ucs525 InRelease
OK:3 https://updates.software-univention.de errata525 InRelease
  python3-wheel univention-container-role-common
Vorgeschlagene Pakete:
  linux-doc-6.1 debian-kernel-handbook
Die folgenden Pakete werden ENTFERNT:
Die folgenden NEUEN Pakete werden installiert:
  linux-image-6.1.0-51-amd64 linux-image-amd64 univention-bind
0 aktualisiert, 7 neu installiert, 1 zu entfernen und 0 nicht aktualisiert.
