Problem: Error with PowerShell module ‘Connect-MicrosoftTeams’
During SSO login from Windows the user gets one of the following errors:
  • In dem Skript auf dieser Seite ist ein Fehler aufgetreten
  • Ungültiges Zeichen
  • require ist undefiniert
2
3
The login popup relies on Internet Explorer (or Edge on newer systems). If you’re experiencing issues, clearing the browser cache and temporary files may help:
  1. Open Internet Options.
  2. Under Browsing history, click Delete and clear Temporary Internet Files and Cookies.
Alternatively, you can bypass the popup with the following Powershell command
Connect-MicrosoftTeams -UseDeviceAuthentication
If needed, provide credentials manually
$cred = Get-Credential
Connect-MicrosoftTeams -Credential $cred -UseDeviceAuthentication
Also take a look here for further information:
Mastodon
