Problem: Diffuse network access problems
You have a master and a backup server. At once you cannot access your shares via hostname anymore.
Investigation:
  • check your dns configuration
  • check your dhcp configuration if it configured the same on both servers.
  • Check your master and backup for a timedifference, and fix this.
