If DHCP Pool is configured in UCS and separate DHCP Statements should be configured for this, these cannot be used because the LDAP schema for DHCP Pool does not contain the extension for dhcpStatements.
Error message: Object class violation: attribute dhcpStatements not allowed
Root Cause Bug 58191
Investigation
In /usr/share/univention-ldap/schema/univention-dhcp.schema
# SUP dhcpPool
objectclass ( 1.3.6.1.4.1.10176.1193
NAME 'univentionDhcpPool'
DESC 'This stores configuration information about a pool.'
SUP top
MUST ( cn $ dhcpRange )
MAY (dhcpClassesDN $ dhcpPermitList $ dhcpLeasesDN $ dhcpOptionsDN $
univentionDhcpFailoverPeer)
X-NDS_CONTAINMENT ('dhcpSubnet' 'dhcpSharedNetwork') )
The schema file can be adapted and extended with the missing dhcpStatements. By restarting the slapd.service, the adapted schema file is adopted and the adaptation can be used. Statements for a DHCP pool can then be configured and saved.
Use an editor of your choice and open the schema file
/usr/share/univention-ldap/schema/univention-dhcp.schema -
Add the missing
dhcpStatementsin the DHCP Pool section.
# SUP dhcpPool
SUP top
univentionDhcpFailoverPeer $ dhcpStatements)
- Restart the
slapd.serviceso that the changes are applied.
/etc/init.d/slapd restart
Result
DN: cn=DHCP-Test,cn=10.200.30.0,cn=mejneschool2,cn=dhcp,ou=mejneschool2,dc=ucs5schoolhejne,dc=intranet
all_clients: None
dynamic_bootp_clients: None
failover_peer: None
known_clients: None
range: 10.200.30.10 10.200.30.100
statements: subnet 10.200.30.128 netmask 255.255.255.192 {
range 10.200.30.129 10.200.30.191;
option routers 10.200.30.1;
option domain-name-servers 8.8.8.8, 1.1.1.1;
option domain-name "ucs5schoolhejne.intranet";
default-lease-time 600;
max-lease-time 7200;
unknown_clients: None
