Problem: dependency issue during oxguard installation
Updateing oxguard shows:
univention-ox-guard : Hängt ab von: open-xchange-guard (>= 2.10.6-7) soll aber nicht installiert werden
Hängt ab von: open-xchange-guard-file-storage (>= 2.10.6-7) soll aber nicht installiert werden
This happens for customers who have integrated ox packages
You have to edit the ox-joinscript
vim /usr/lib/univention-install/65univention-ox.inst
→ VERSIONG='2.10.7'  # Guard
univention-run-join-scripts --force --run-scripts 65univention-ox.inst
apt update
univention-app install open-xchange-guard
Bug 56276
During the last changes, the workaround is not usable anymore, so we provide the next one:
Add the repository manually (temporarily) to sources.list
deb https://$OXUSER:$OXPASSWORD@software.open-xchange.com/OX6/OXSEforUCS/5.0/maintained/component/oxguard2107/ ./
Install the deb package manually:
apt-get update && apt-get install open-xchange-guard
Install the univention app open-xchange-guard
Access Denied may still apply, you could need to re-run the 93univention-ox.inst to have the repository in /etc/apt/sources.list.d/20_ucs-online-component.list
 univention-run-join-scripts --force --run-scripts 93univention-ox.inst
